Your basket is empty
Kodak Ngenuity 9150DC Scanner
Quicklinx: 9M4BWS00 Mfr#: 8517476
Kodak Ngenuity series scanners - the next scanning innovation in Kodak's document imaging solutions' portfolio - deliver an unprecedented combination of intelligent paper handling, 40% larger feeder capacity than other scanners in their class and razor-sharp image quality, with the added benefits of a user-friendly interface, easy maintenance and a low cost of consumables. Users across industries can now convert a wider range of documents into high-quality digital images, quickly and more efficiently than ever before. It's an ingenious way to make, manage, and move images and information.
Kodak Ngenuity 9150 - document scanner - USB 2.0, SCSI
Document scanner
Interface Type
USB 2.0, SCSI
Scan Element Type
CCD
Light Source
White LED
Max Supported Document Size
318 x 1016 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
150 ppm (mono) / 150 ppm (colour)
Max Document Size
318 mm x 1016 mm
Automatic Duplexing
Supported Document Type
Plain paper, card scanner
Document Feeder Type
Automatic
Document Storage Capacity
700 pages
Duty Cycle
150000 scans per day
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
Microsoft Certification
Certified for Windows Vista
52.1 cm x 76.2 cm x 49.5 cm
50.8 kg
Environmental Standards
ENERGY STAR Qualified
3 months warranty
Document scanner
Interface Type
USB 2.0, SCSI
318 x 1016 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Scan Element Type
CCD
Bulb / Light Source Type
White LED
Max Document Scan Speed B/W
150 ppm
Max Document Scan Speed Colour
150 ppm
Duty Cycle
Scanner Speed Details
150 ppm - landscape colour - Letter - 200 dpi , 300 ipm - duplex - landscape colour - Letter - 200 dpi , 150 ppm - landscape B&W - Letter - 200 dpi , 300 ipm - duplex - landscape B&W - Letter - 200 dpi , 120 ppm - portrait colour - Letter - 200 dpi , 240 ipm - duplex - portrait colour - Letter - 200 dpi , 120 ppm - portrait B&W - Letter - 200 dpi , 240 ipm - duplex - portrait B&W - Letter - 200 dpi , 150 ppm - landscape greyscale - Letter - 200 dpi , 300 ipm - duplex - landscape greyscale - Letter - 200 dpi , 120 ppm - portrait greyscale - Letter - 200 dpi , 240 ipm - duplex - portrait greyscale - Letter - 200 dpi
Scanner Features
Ultrasonic multifeed sensor, Multi-feed Ignore, Variable Feeder Tray Capacity Control, Straight Pass Through Paper Path
TWAIN, ISIS
Media Handling
Max Document Size
318 mm x 1016 mm
Automatic
700 pages
SCSI - HD-68 , USB 2.0 - Type B
Starter cleaning kit, camera calibration kit
1 x USB cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
175 Watt (6.7 Watt)
Software Included
Drivers & Utilities, Kofax VirtualReScan Professional, KODAK Ngenuity Operator Utility (NOU)
System Requirements Details
Windows XP/Vista/7 - Pentium D - 2 GHz - RAM 1 GB - HD 250 GB , Windows XP/Vista/7 - Athlon - 2 GHz - RAM 1 GB - HD 250 GB
52.1 cm
76.2 cm
49.5 cm
50.8 kg
Limited warranty - 3 months - on-site - response time: 4 hours
10 °C
38 °C
10 - 80% (non-condensing)
Sound Emission
71.4 dBA
