Product
Brand
Kodak Ngenuity 9125DC Scanner
Quicklinx: 9M43WS00 Mfr#: 8516254
Kodak Ngenuity series scanners - the scanning innovation in Kodak's document imaging solutions' portfolio - deliver an unprecedented combination of intelligent paper handling, 40% larger feeder capacity than other scanners in their class and razor-sharp image quality, with the added benefits of a user-friendly interface, easy maintenance and a low cost of consumables. Users across industries can convert a wider range of documents into high-quality digital images, quickly and more efficiently than ever before. It's an ingenious way to make, manage, and move images and information.
Kodak Ngenuity 9125 - document scanner - desktop - USB 2.0, SCSI
Document scanner - desktop
Interface Type
USB 2.0, SCSI
Scan Element Type
CCD
Light Source
White LED
Max Supported Document Size
318 x 1016 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
125 ppm (mono) / 100 ppm (colour)
Max Document Size
318 mm x 1016 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
700 pages
Duty Cycle
125000 scans per day
Microsoft Certification
Certified for Windows Vista
52.1 cm x 76.2 cm x 49.5 cm
50.8 kg
Environmental Standards
ENERGY STAR Qualified
3 months warranty
Interface Type
USB 2.0, SCSI
318 x 1016 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single/duplex pass
Automatic Duplexing
Scan Element Type
CCD
Bulb / Light Source Type
White LED
Max Document Scan Speed B/W
125 ppm
Max Document Scan Speed Colour
100 ppm
Duty Cycle
Scanner Speed Details
125 ppm - landscape - Letter - 200 dpi , 250 ipm - landscape - Letter - 200 dpi , 100 ppm - portrait - 200 dpi , 200 ipm - portrait - 200 dpi
TWAIN, ISIS
Media Handling
Max Document Size
318 mm x 1016 mm
Plain paper
Automatic
700 pages
SCSI - HD-50 , USB 2.0 - Type B
1 x USB cable
Certified for Windows Vista software and devices have undergone compatibility tests for ease-of-use, better performance and enhanced security.
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
175 Watt (6.7 Watt)
Software Included
Drivers & Utilities, Kofax VirtualReScan Professional, KODAK Ngenuity Operator Utility (NOU)
52.1 cm
76.2 cm
49.5 cm
50.8 kg
Limited warranty - 3 months - on-site - response time: 4 hours
10 °C
38 °C
10 - 80%
Sound Emission
71.4 dBA
