Your basket is empty
Kodak Ngenuity 9090DC Scanner
Quicklinx: 9M49WS00 Mfr#: 1598143
Kodak Ngenuity series scanners - the next scanning innovation in Kodak's document imaging solutions' portfolio - deliver an unprecedented combination of intelligent paper handling, 40% larger feeder capacity than other scanners in their class and razor-sharp image quality, with the added benefits of a user-friendly interface, easy maintenance and a low cost of consumables. Users across industries can now convert a wider range of documents into high-quality digital images, quickly and more efficiently than ever before. It's an ingenious way to make, manage, and move images and information.
Kodak Ngenuity 9090DC - document scanner - desktop - USB 2.0, SCSI
Document scanner - desktop
Interface Type
USB 2.0, SCSI
Scan Element Type
CCD
Max Supported Document Size
318 x 1016 mm
Input Type
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
90 ppm (mono) / 70 ppm (colour)
Max Document Size
318 mm x 1016 mm
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
700 pages
Duty Cycle
90000 scans per day
Microsoft Certification
Compatible with Windows 7
52.1 cm x 76.2 cm x 49.5 cm
50.8 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0, SCSI
318 x 1016 mm
Scanner
Input Type
Optical Resolution
600 dpi x 600 dpi
Scan Mode
Single/duplex pass
Scan Element Type
CCD
Max Document Scan Speed B/W
90 ppm
Max Document Scan Speed Colour
70 ppm
Duty Cycle
90000 scans per day
Scanner Speed Details
90 ppm - landscape - Letter - 200 dpi , 180 ipm - landscape - Letter - 200 dpi , 70 ppm - portrait - 200 dpi , 140 ipm - portrait - 200 dpi
TWAIN, ISIS
Media Handling
Max Document Size
318 mm x 1016 mm
Plain paper
Automatic
700 pages
SCSI - HD-50 , USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
Internal power supply
Power Consumption Operational (Standby)
175 Watt (6.7 Watt)
52.1 cm
76.2 cm
49.5 cm
50.8 kg
10 °C
38 °C
10 - 80%
Sound Emission
71.4 dBA
