Product
Kodak i3450 A3 Document Scanner
Quicklinx: 9M41WS00 Mfr#: 1992874
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 305 x 864 mm
Interface: USB 2.0
Compatibility: PC
  • Windows 8 (32/64 bits)
Hurry, only 1 left in stock!
£2,983.81 ex VAT
£3,580.57 inc VAT
The Kodak i3000 series scanner is purpose-built to deliver consistent throughput and minimize downtime for your office. It is loaded with impressive imaging functionality for on boarding of information, and intelligent document protection to defend against damaged documents and lost data. The A3 rotary scanner can take on virtually any challenge while taking up less space on your desk - making it the perfect fit for any business that doesn't have a second to waste.
  • Missions accomplished
    The Kodak i3000 series delivers consistently high throughput. Whether you're scanning in color or black and white, at 300 dpi, images, text or mixed-size documents - it doesn't matter, it just gets done.
  • Give productivity a major lift
    Stack up the work. With a 250-sheet feeder/elevator you can neatly and efficiently scan document batches with ease. The design ensures continuous throughput with rapid-fire scanning and less risk of jamming.
  • It's even smart enough to know when something's not right
    Intelligent document protection provides an added level of document and data safeguarding. "Intelligent" because it listens for the very first indication of potential document damage from staples, paper clips or other obstructions. At the initial sound of any issue, sensors stop the scanning process to allow you to take appropriate action and correct the irregularity.
  • Better than ever
    Kodak Alaris' Perfect Page technology optimizes image quality and intelligently manages a host of image processing tasks. It all happens automatically, with every scan.
  • Intelligent by design
    Scanning is really only half the story. Configuring image profiles, defining job names and file destinations, and distributing information is truly crucial. That's where Kodak Alaris' Smart Touch functionality takes over. It streamlines repetitive tasks like filing to your server, simplifies distribution of content, and makes access to your data easy, whether you're in the office or out on the road.
  • Works incredibly well with others
    Easily integrates with all TWAIN, ISIS, and Linux-based scanning applications so managing your data is just as easy as scanning your documents.
  • Built to meet the demands of today and the rigors of tomorrow
    Make no mistake, these scanners are made to last. Designed to impress your most experienced employees and make life easier for workers who are just getting started. When it comes to getting work done day after day, depend on scanners that truly deliver.
  • Flexible input for inflexible documents
    Some contracts are not just unbreakable, they're unbendable, too. For those instances, simply choose the straight-through paper path option. This bypasses rotary scanning, enabling you to feed thick or exceptionally long documents right through.
  • Impact made compact
    Proof that a smaller design doesn't have to compromise features, it has managed to engineer heavy-duty features into a device that takes up less space on your desk and less time in your day.
  • The smart touch graphical user display
    Pre-configured scanning setups make common, yet complicated scanning tasks easy.
Kodak i3450 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scan Element Type
Dual CCD
Light Source
Dual LED
Max Supported Document Size
305 x 864 mm
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
90 ppm (mono) / 80 ppm (colour)
Max Document Size
305 mm x 864 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
250 sheets
Duty Cycle
20000 scans per day
Microsoft Windows Vista (32/64 bits) SP2, Ubuntu 10.04, Microsoft Windows 7 (32/64 bits) SP1, Microsoft Windows XP (32/64 bits) SP3, Windows 8 (32/64 bits)
43.18 cm x 37.1 cm x 25.7 cm
17.7 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
305 x 864 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Automatic Duplexing
Scan Element Type
Dual CCD
Bulb / Light Source Type
Dual LED
Max Document Scan Speed B/W
90 ppm
Max Document Scan Speed Colour
80 ppm
Duty Cycle
20000 scans per day
Scanner Speed Details
90 ppm - landscape B&W - Letter - 300 dpi , 180 ipm - duplex - landscape B&W - Letter - 300 dpi , 90 ppm - landscape greyscale - Letter - 300 dpi , 180 ipm - duplex - landscape greyscale - Letter - 300 dpi , 80 ppm - landscape colour - Letter - 300 dpi , 160 ipm - duplex - landscape colour - Letter - 300 dpi
Scanner Features
Color Dropout, Ultrasonic Double Feed Detection, Automatic Image Orientation, automatic colour detection, built-in LCD screen, Auto Crop, iThresholding, Perfect Page, dual-stream scanning, adaptive threshold processing, image merge, auto brightness, Deskew, Blank Page Detection
TWAIN, ISIS, WIA
Media Handling
Max Document Size
305 mm x 864 mm
Plain paper
Automatic
250 sheets
USB 2.0
1 x SuperSpeed USB cable
UL, TUV GS, C-Tick, cUL, EN 61000-3-3, EN55024, CISPR 22, EN55022 Class B, ICES-003 Class B, CCC, UL 60950-1, IEC 60950-1, EN 60950-1, FCC CFR47 Part 15 B, S Mark, BSMI CNS 14336, GB 4943, GB 9254 Class B, GB 17625.1, CAN/CSA C22.2 No. 60950-1-07, AS/NZS, VCCI Class B
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
75 Watt
Software Included
Drivers & Utilities, KODAK Smart Touch, KODAK Capture Pro Software
43.18 cm
37.1 cm
25.7 cm
17.7 kg
15 °C
35 °C
15 - 80%
Sound Emission
60 dBA
Interface: USB 2.0
Compatibility: PC
Brand: Kodak
Price Range Ex VAT: 1500+
