Brand
Kodak i3300 Scanner
Quicklinx: DKCTWS00 Mfr#: 1140003
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Kodak i3300 Scanner scans up to 70 pages per minute, black and white lettersize documents at 200 dpi in landscape orientation.
Kodak i3300 - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Dual CCD
Light Source
Dual LED
Max Supported Document Size
305 x 4100 mm
Input Type
Grayscale / Color Depth
48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Interpolated Resolution
1200 dpi x 1200 dpi
Max Document Scan Speed
70 ppm (mono) / 70 ppm (colour)
Max Document Size
305 mm x 4100 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
250 sheets
Duty Cycle
25000 scans per day
Microsoft Windows Vista (32/64 bits) SP2, Microsoft Windows 7 (32/64 bits) SP1, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Ubuntu 14.04 LTS, Windows 10 (32/64 bits)
43.18 cm x 37.1 cm x 23.8 cm
15.8 kg
Environmental Standards
ENERGY STAR Qualified
90 days warranty
Interface Type
USB 2.0
305 x 4100 mm
Scanner
Input Type
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
Optical Resolution
600 dpi x 600 dpi
1200 dpi x 1200 dpi
Automatic Duplexing
Dual CCD
Bulb / Light Source Type
Dual LED
Max Document Scan Speed B/W
70 ppm
Max Document Scan Speed Colour
70 ppm
Duty Cycle
25000 scans per day
Scanner Speed Details
70 ppm - A4
Scanner Features
Color Dropout, Automatic Image Orientation, automatic colour detection, built-in LCD screen, Auto Crop, iThresholding, Perfect Page, dual-stream scanning, adaptive threshold processing, image merge, Ultrasonic Multi Feed Detection, auto brightness, Deskew, Blank Page Detection, Continuous Scanning
Scan File Formats
BMP, JPEG, TIFF, PDF, RTF
TWAIN, ISIS, WIA
Media Handling
Max Document Size
305 mm x 4100 mm
Plain paper
Automatic
250 sheets
USB 2.0
1 x USB cable
FCC Class B certified, TUV GS, C-Tick, CISPR 22 Class B, cUL, EN 61000-3-3, CCC, IEC 60950-1, FCC CFR47 Part 15 B, S Mark, BSMI CNS 14336, GB 9254 Class B, CAN/CSA C22.2 No. 60950-1-07, GB 9254-2008, UL 60950-1-07, ICES-003 issue 5 Class B, CNS13438:2006, VCCI V-3/2012.04 Class B, EN 60950-1:2006+ A11, GB 17625.1-2003, EN 55024:2010, AS/NZS CISPR22:2009+A1:2010, GB 4943.1-2011, EN 55022:2010 Class B
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
49 Watt
Power Consumption Sleep
2.8 Watt
Software Included
Drivers & Utilities, KODAK Smart Touch, KODAK Capture Pro Software Limited Edition
43.18 cm
37.1 cm
23.8 cm
15.8 kg
Limited warranty - advance hardware replacement - 90 days
15 °C
35 °C
15 - 80%
Sound Emission
60 dBA
