The wireless and network Kodak i1190WN Scanner makes life a lot easier and more efficient for any business. It is perfect for sharing and work collaborations. You can easily integrate it with your existing business applications and create custom integrations. And you can even manage security levels and settings. Welcome to a new world of flexible, versatile, powerful, convenient and stress-free scanning. Don't let your business miss out on the power of wireless network scanners.
- Kodak i1190WN - document scanner - desktop - USB 2.0, LAN, Wi-Fi(n)
- Document scanner - desktop
- Interface Type
- Scan Element Type
- CMOS / CIS
- Light Source
- Dual LED
- Additional Functions
- Scan to print, scan to network share, scan to cloud, scan to smart devices, scan to FTP, scan to file, scan to folder
- Max Supported Document Size
- 215 x 355.6 mm
- Input Type
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 40 ppm (mono) / 40 ppm (colour)
- Max Document Size
- 215 mm x 355.6 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, card scanner, embossed card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 75 sheets
- Duty Cycle
- 5000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows Server 2008 (64-bits), Microsoft Windows Server 2012 (64-bit), Microsoft Windows Vista / 7 / 8 / 8.1 / 10 (32/64 bits)
- 33 cm x 16.2 cm x 24.6 cm
- 3.2 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- 215 x 355.6 mm
Scanner
- Input Type
- 600 dpi x 600 dpi
- Scan Element Type
- CMOS / CIS
- Bulb / Light Source Type
- Dual LED
- Max Document Scan Speed B/W
- 40 ppm
- Max Document Scan Speed Colour
- 40 ppm
- Barcodes
- UPC-A, UPC-E, Codabar, Code 128, Code 3 of 9, Interleaved 2 of 5, PDF417, EAN-8, EAN-13
- Duty Cycle
- Scanner Speed Details
- 40 ppm - 300 dpi , 80 ipm - duplex
- Scanner Features
- Intelligent Document Protection
- Scan File Formats
- BMP, JPEG, PNG, TIFF
- TWAIN, ISIS
Media Handling
- Max Document Size
- 215 mm x 355.6 mm
- Automatic
- 75 sheets
- USB 2.0 , LAN
- ENERGY STAR Certified
- Voltage Required
- Power Consumption Operational (Standby)
- 21 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- OS Required
- 33 cm
- 16.2 cm
- 24.6 cm
- 3.2 kg
- 15 °C
- 35 °C
- 15 - 80%
- Sound Emission
- 20 dBA
