To keep your business process humming, you need a scanning solution that combines great image quality, simple operation and time-saving productivity. The latest Kodak i2000 Series Scanners offer all that in a very small yet powerful package.
Impressive productivity
Save time by using Smart Touch technology to perform multi-step scanning processes with the press of a button. Built-in barcode reading delivers data to applications. No waiting for warmup: start scanning instantly with always-ready LED light. Scan larger batches in input trays that hold up to 100 pages. Streamline mixed jobs: the scanner automatically recognizes color pages, bypasses blank pages, and orients every document so it's right-side up. -
Endless versatility
Handle almost anything: small documents or large, thick or thin, ID cards, even embossed hard cards. Mix small, large, thin and thick documents in one batch. -
Better image quality
Capture images with greater consistency, clarity, and color. Built-in Perfect Page technology can deliver scans even clearer than the original documents. Read and capture text flawlessly for more accurate OCR. Consistently great image quality means you'll virtually eliminate rescanning or post-image processing. -
Space-saving design
The even-more-compact stow-or-go design lets you store the scanner upright when not in use. -
No expertise required
Smart Touch technology lets you perform up to nine different tasks with the push of a button - including creating PDFs, attaching documents to e-mails, organizing them in folders, or sending them to Cloud services. Easy-to-read control panel makes scanning documents simple.
- Kodak i2620 - document scanner - desktop - USB 2.0
- Document scanner - desktop
- Interface Type
- USB 2.0
- Scanning Sensor Type
- Dual CCD
- Light Source
- Dual LED
- Max Supported Document Size
- 216 x 4064 mm
- Input Type
- Grayscale / Color Depth
- 48-bit colour
- Grayscale / Color Depth (External)
- 8-bit (256 grey levels) / 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Max Document Scan Speed
- 60 ppm (mono) / 60 ppm (colour)
- Max Document Size
- 216 mm x 4064 mm
- Supported Document Type
- Plain paper, business card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 100 sheets
- Duty Cycle
- 7000 scans per day
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows XP SP2, Microsoft Windows Vista (32/64 bits) SP1, Microsoft Windows XP SP3, Microsoft Windows Server 2008 x64 Edition, Microsoft Windows XP 64-bit Edition SP2, Ubuntu 10.04, Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits), Apple OS X 10.9 Mavericks, Apple MacOS X 10.10
- 33 cm x 16.2 cm x 24.6 cm
- 5.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- USB 2.0
- 216 x 4064 mm
Scanner
- Input Type
- Grayscale Depth (External)
- Colour Depth
- 48-bit colour
- Colour Depth (External)
- 24-bit (16.7 million colours)
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- Dual CCD
- Bulb / Light Source Type
- Dual LED
- Max Document Scan Speed B/W
- 60 ppm
- Max Document Scan Speed Colour
- 60 ppm
- Duty Cycle
- Scanner Speed Details
- 60 ppm - black & white - 200 dpi , 60 ppm - black & white - 300 dpi , 60 ppm - colour - 200 dpi , 120 ipm - black & white - 300 dpi , 120 ipm - black & white - 200 dpi , 120 ipm - colour - 200 dpi , 40 ppm - colour - 300 dpi , 80 ipm - colour - 300 dpi
- Scanner Features
- Automatic Image Orientation, Ultrasonic multifeed sensor, automatic colour detection, built-in LCD screen
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 216 mm x 4064 mm
- Automatic
- 100 sheets
- USB 2.0 - Type A
- TUV GS, C-Tick, VCCI Class B ITE, CISPR 22 Class B, BSMI CNS 13438 Class B, cUL, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, UL 60950-1, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-07, FCC CFR47 Part 15 B, S Mark, AS/NZS 3548 Class B, BSMI CNS 14336, GB 4943, GB 9254 Class B, GB 17625.1
- ENERGY STAR Certified
- Power Device
- Internal power supply
- Voltage Required
- Power Consumption Operational (Standby)
- 32 Watt
- Power Consumption Stand by
- 0.35 Watt
- Power Consumption Sleep
- 4 Watt
- OS Required
- System Requirements Details
- Windows XP/Vista/7/8 - Core 2 Duo - 2.4 GHz - RAM 4 GB , MacOS - Core i7 - 2 GHz - RAM 4 GB
- 33 cm
- 16.2 cm
- 24.6 cm
- 5.5 kg
- 10 °C
- 35 °C
- 15 - 80%
