Your basket is empty
Kingston ValueRAM Kingston 4GB 2400MHz DDR4 ECC Reg CL17 DIMM 1Rx8
Quicklinx: C571WS00 Mfr#: KVR24R17S8/4
Type: DDR4 SDRAM
Capacity: 4GB
Connection: DIMM 288-pin
Speed: 2400MHz
Data Integrity: ECC
£45.29 ex VAT
£54.34 inc VAT
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR4 - 4 GB - DIMM 288-pin
RAM memory
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17 (17-17-17)
Temperature monitoring, single rank, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, registered with parity
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.23
Speed
Latency Timings
CL17 (17-17-17)
ECC
Module Configuration
512 x 72
Chips Organization
512 x 8
Voltage
1.2 V
Lead Plating
Gold
Colour Category
Green
RoHS
Kingston ValueRAM Kingston 4GB 2400MHz DDR4 ECC Reg CL17 DIMM 1Rx8 Bundle deal on Kingston ValueRAM Kingston 4GB 2400MHz DDR4 ECC Reg CL17 DIMM 1Rx8
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £5.30 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £1.60 | while stocks last
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £9.40 | in stock
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £5.43 | in stock
£61.32
saving £5.71
Type: DDR4 SDRAM
Capacity: 4GB
Speed: 2400MHz
Data Integrity: ECC
Registered/Buffered: Registered with parity
CAS Latency: CL17
Standard: PC4-19200
Brand: Kingston ValueRAM
Price Range Ex VAT: 0 - 50
