Kingston ValueRAM 4GB DDR3 1333MHz Non-ECC SO DIMM CL9 SR x8
Quicklinx: 84YMWS00 Mfr#: KVR13S9S8/4
Type: DDR3 SDRAM
Capacity: 4GB
Connection: SO-DIMM 204-pin
Speed: 1333MHz
Data Integrity: Non-ECC
44 in stock
£19.12 ex VAT
£22.94 inc VAT
Standard delivery Delivered within 3-5 working days
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3 - module - 4 GB - SO-DIMM 204-pin - unbuffered
Memory module
4 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Single rank, unbuffered
Voltage
1.5 V
Lead Plating
Gold
4 GB
Upgrade Type
Generic
DRAM memory module
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL9
Non-ECC
Module Configuration
512 x 64
Chips Organization
X8
Voltage
1.5 V
Lead Plating
Gold
Type: DDR3 SDRAM
Capacity: 4GB
Speed: 1333MHz
Registered/Buffered: Unbuffered
CAS Latency: CL9
Standard: PC3-10600
Brand: Kingston ValueRAM
Price Range Ex VAT: 0 - 50
