Kingston ValueRAM 4GB DDR3 1333MHz Non-ECC DIMM 240-pin CL9 SR x8 30mm Height
Quicklinx: 84YLWS00 Mfr#: KVR13N9S8H/4
Type: DDR3 SDRAM
Capacity: 4GB
Connection: DIMM 240-pin
Speed: 1333MHz
Data Integrity: Non-ECC
£20.59 ex VAT
£24.70 inc VAT
Kingston® offers extremely reliable, high-performance desktop memory and sells more notebook upgrade memory than anyone in the world. Every and every module is customised and tested to meet the exact specification requirements of each system. Kingston memory can increase the processing power of your notebook or desktop. It’s guaranteed to be compatible and offers a great cost-performance benefit plus better multitasking, faster processing of multimedia files, smoother video streaming and an enhanced gaming experience. For added peace of mind, Kingston memory is backed by a lifetime warranty, free technical support and legendary Kingston reliability.
Improve Performance
If your system is lagging or a program doesn’t respond or won’t load, you may have a memory shortage. You may see subtle signs, like poor performance in everyday tasks, or you may be receiving "out of memory" messages. Add reliable Kingston memory and watch your productivity soar. Pages may load faster and launching new applications may be easier and faster, leaving you more time for that important project.
Build your own PC
Thinking of building your own rig? It’s a great way to get exactly what you want in a system. Before you start, consider your motherboard’s technology. Is it DDR3 or DDR4? How many slots are available for memory? Does it have to be installed in pairs, triplets or quads? At what speed do you want your memory to perform? By answering these questions, you’ll have a better idea of what you need and what Kingston memory will work best in your system.
Replace your memory
In case your memory fails, rest assured that Kingston can deliver what you need to get back up and running. If you’re using a brand-name system or you know the name of your whitebox system’s motherboard, use our configurator to find the right module. If you know the specs of the memory in your whitebox system, our product selection tool is for you. Finding the memory you need is easy with Kingston.
Kingston ValueRAM - DDR3 - 4 GB - DIMM 240-pin - unbuffered
RAM memory
4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Single rank, unbuffered
Voltage
1.5 V
Lead Plating
Gold
4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL9
Non-ECC
Module Configuration
512 x 64
Chips Organization
X8
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Type: DDR3 SDRAM
Capacity: 4GB
Speed: 1333MHz
Registered/Buffered: Unbuffered
CAS Latency: CL9
Standard: PC3-10600
Brand: Kingston
Stock Status: Clearance
Price Range Ex VAT: 0 - 50
