Your basket is empty
Kingston ValueRAM 2GB (1x2GB) DDR3L 1600MHz Non-ECC SODIMM 204-pin CL9
Quicklinx: 9MB6WS00 Mfr#: KVR13LS9S6/2
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3L - 2 GB - SO-DIMM 204-pin
RAM memory
2 GB
Memory Type
DDR3L SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3L-10600)
Latency Timings
CL9 (9-9-9)
Single rank, eight banks, On-Die Termination (ODT), Low Voltage, unbuffered
Voltage
1.35 / 1.5 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
2 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
SO-DIMM 204-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL9 (9-9-9)
Non-ECC
Module Configuration
256 x 64
Chips Organization
256 x 16
Voltage
1.35 / 1.5 V
Lead Plating
Gold
Compatible Slots
1 x memory - SO-DIMM 204-pin
