Kingston ValueRAM 1GB 800MHz DDR2 Non-ECC
Customer rating: 5.0* (Write a review)
Quicklinx: 4NWLWS00 Mfr#: KVR800D2N5/1G
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
This memory is designed for the following motherboards:
ASUS M2N-SLI Deluxe;
ASUS M2N32-SLI Deluxe;
ASUS M2NPV-MX;
ASUS M2NPV-VM;
ASUS P5WD2-E Premium;
ASUS P5WDG2-WS;
EliteGroup (ECS) RS485M-M;
Gigabyte GA-M51GM-S2G;
Gigabyte GA-M55plus-S3G;
MSI K9N Diamond;
MSI K9N Neo-F;
MSI K9N Platinum;
MSI K9N SLI Platinum.
Kingston ValueRAM - DDR2 - module - 1 GB - DIMM 240-pin - 800 MHz / PC2-6400 - unbuffered
Memory module
1 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
800 MHz (PC2-6400)
Latency Timings
CL5
Unbuffered
Voltage
1.8 V
Lead Plating
Gold
Limited lifetime warranty (Germany, Austria and France - 10 years)
ABIT NP-M2P; ASUS CROSSHAIR Republic of Gamers, M2N, M2N32; DFI UT ICFX3200; ECS C51, K8M890, KA3, NFORCE4M, PX1, RS485; EPoX EP-MF4-J3; Foxconn G9657, MCP61; Fujitsu D2312; Gigabyte GA-MA78, MF3; Sapphire PURE CrossFire 3200 Advantage; PURE Element PE-AM2RS485; Shuttle XPC SS30; SUPERMICRO PDSBA+
1 GB
Upgrade Type
Generic
DRAM memory module
DDR2 SDRAM
DIMM 240-pin
Speed
800 MHz (PC2-6400)
Latency Timings
CL5
Non-ECC
Unbuffered
Module Configuration
128 x 64
Chips Organization
64 x 8
Voltage
1.8 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
ABIT AB9, AB9 Pro, AW9D, AW9D-MAX, IN9 32X-MAX, NF-M2 nView, NF-M2S, NP-M2P , ASUS CROSSHAIR Republic of Gamers, M2N, M2N 1394, M2N DH, M2N32 WS Professional, M2N32-SLI Deluxe, M2N4-SLI, M2N8-VMX, M2NBP-VM CSM, M2N-E, M2N-E SLI, M2N-LR, M2N-MX, M2N-VM DH, M2R32-MVP, M2V-MX, P5B Deluxe/WiFi-AP AiLifestyle Series, P5B-E AiLifestyle Series, P5B-E Plus AiLifestyle Series, P5B-V AiLifestyle Series, P5B-V DH Deluxe/HDMI Digital Home Series, P5B-VM AiLifestyle Series, P5N32-SLI Premium/WiFi-AP AiLifestyle Series, P5N32-SLI SE Deluxe AI Lifestyle Gaming Edition, P5W64 WS Professional, P5WDG2 WS Professional Main Station Series, Striker Extreme Republic of Gamers Series , Biostar TForce 550, TForce 570 U, TForce 570 U Deluxe, TForce 590 SLI Deluxe, TForce 6100 AM2, TForce 965PT, TForce P965 Deluxe, TForce4 AM2, TForce4 U AM2 , DFI Infinity nF550-M2/G, Infinity nF570-M2/G, UT ICFX3200-T2R/G, UT NF590 SLI-M2R/G , ECS C51GM-M, K8M890M-M, KA3 MVP, NFORCE4M-A, PX1, RS485M-M , EPoX EP-5P965+ GLI, EP-AD580 XR, EP-AF550 PRO, EP-AF570+ Ultra, EP-AF590 SLI2, EP-AGF6110-M, EP-MF4 Ultra-3, EP-MF4-3, EP-MF4-J3, EP-MF570 SLI, EP-MGF6100-M , Foxconn 975X7AB-8EKRS2H, C51XEM2AA-8EKRS2H, G9657MA-8EKRS2H, K8M890M2MA-RS2H, MCP61PM2MA-8EKRS2H, MCP61SM2MA-ERS2H, P9657AA-8EKRS2H, P9657AA-8KS2H , Fujitsu D2312-C , Gigabyte GA-965G-DS3, GA-965G-DS4, GA-965GM-S2, GA-965P-DQ6, GA-965P-DS3, GA-965P-DS4, GA-965P-S3, GA-G1975X-C, GA-M55SLI-S4, GA-M55S-S3, GA-M59SLI-S4, GA-M61PM-S2, GA-M61VME-S2, GA-MA78G-DS3H, GA-MF3 , Intel Desktop Board D975XBX2 , MSI 975X Platinum PowerUp Edition, 975X Platinum V.2, G965M-F, G965M-FI, G965M-FIR, K9A Platinum, K9AGM, K9MM-V, K9N Ultra, K9N6PGM-F, K9NBPM2-FID, K9NGM2, K9SGM, K9VGM, K9VGM-V, P965 Neo, P965 Neo-F, P965 Platinum, Q965MDO , Sapphire PURE CrossFire 3200 Advantage PC-AM2RD580ADV , Sapphire PURE Element PE-AM2RS485M , Shuttle XPC SK22G2, SS30G2, SS30G2 SE , SUPERMICRO PDSBA, PDSBA+
Customer reviews
Write a review for the Kingston ValueRAM 1GB 800MHz DDR2 Non-ECC here!
Excelelnt speed, overclockable, value!!!!!
Reviewed by Dan. Review Posted 18/01/2008
Overclocked by 10%, not bad for value ram.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
