Your basket is empty
Kingston USB 3.0 Multiview Adapter EU
Quicklinx: C048WS00 Mfr#: K33974EU
19 in stock
£65.28 ex VAT
£78.33 inc VAT
Standard delivery Delivered within 3-5 working days
The Kensington Multi-Display Adapter allows you to expand your viewing options and add a secondary screen to your laptop, Ultrabook, Windows 8 tablet, MacBook or other Apple computer. It allows a secondary display to increase your productivity or give you the confidence when presenting that you can connect to any projector or TV screen via a single USB. For instant connectivity and superb picture quality between laptop and additional display, the Kensington Universal Multi-Display Adapter uses a USB 3.0 SuperSpeed connection.
Research has shown that using multiple monitors can increase productivity by up to 50%. Common tasks such as copying and pasting are greatly improved with fewer errors thanks to not having to juggle or tab through your open windows within one display. The Kensington Multi-Display Adapter makes adding that extra screen easy. Simply connect one end to the monitor and the other to your laptop or Ultrabook USB port. The Universal Multi-Display Adapter can also be used on projectors or HDTV screens using the included DVI-VGA adapter, allowing display on any device with up to 2048x1152 pixel resolution or 1080p for video playback. Using USB means its universally compatible with any brand and model, including Ultrabooks. All you need is one USB to add another display option.
Kensington Universal Multi-Display Adapter external video adapter - black
External video adapter
Bus Type
SuperSpeed USB 3.0
DVI-I (dual link) , USB 3.0
Enclosure Colour
Europe
Bus Type
SuperSpeed USB 3.0
1 x USB cable , 1 x DVI-VGA adapter
Software Included
Drivers & Utilities
Enclosure Colour
Europe
Brand: Kingston
Price Range Ex VAT: 50 - 100
