Kingston SSDNow A400 480GB SATA 6Gb/s SSD
Quicklinx: CX2HWS00 Mfr#: SA400S37/480G
Form Factor: 2.5"
Capacity: 480GB
Interface: Serial ATA-600
Type: Internal hard drive
More than 50 in stock
£55.16 ex VAT
£66.19 inc VAT
Pro
Kingston’s A400 solid-state drive dramatically improves the responsiveness of your existing system with incredible boot, loading and transfer times compared to mechanical hard drives. Powered by a latest-gen controller for read and write speeds of up to 500MB/s and 450MB/s1, this SSD is 10x faster than a traditional hard drive1 for higher performance, ultra-responsive multi-tasking and an overall faster system.
Also more reliable and durable than a hard drive, A400 is built with Flash memory. There are no moving parts, making it less likely to fail than a mechanical hard drive. It’s also cooler and quieter, and its shock and vibration resistance makes it ideal for notebooks and other mobile computing devices.
A400 is available in Multiple capacities from 120GB–480GB2 to give you all the space you need for applications, videos, photos and other important documents. You can also replace your hard drive or a smaller SSD with a drive big enough to hold all your files.
This SSD is designed for use in desktop and notebook computer workloads, and is not intended for server environments.
Kingston A400 - solid state drive - 480 GB - SATA 6Gb/s
Solid state drive - internal
480 GB
NAND Flash Memory Type
Triple-level cell (TLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
69.9 mm x 100 mm x 7 mm
41 g
3-year warranty
480 GB
2.5"
SATA 6Gb/s
69.9 mm
100 mm
7 mm
41 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
500 MBps (read) / 450 MBps (write)
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
0.195 Watt (idle) , 0.279 Watt (average) , 0.642 Watt (read) , 1.535 Watt (write)
ISO 9001, SGS
Limited warranty - 3 years
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
Form Factor: 2.5"
Capacity: 480GB
Brand: Kingston
Price Range Ex VAT: 50 - 100
