Kingston's M.2 SATA G2 SSD is a thin and compact, caseless internal solid state drive that combines high capacity with low power consumption to serve as a reliable caching device or primary storage for the OS and applications. Suitable for popular Small Form Factor (SFF) PCs including Ultrabooks, notebooks, and tablets, the M.2 2280 SATA G2 SSD easily integrates into designs with M.2 connectors and is ideal for system builders and DIY end users. Lighter weight than a cased SSD, the M.2 SATA G2 SSD optimizes performance with advanced garbage collection, wear-leveling and TRIM support to keep performance consistent over the life of the drive. DevSleep, a recent addition to the SATA specification, is an efficient power management option that minimizes power consumption and extends battery life. Firmware-based power loss protection maintains data integrity and ensures data in cache is constantly flushed and hardened to NAND to enable the drive to recover in the event of an unsafe shutdown.
M.2 form factor
Multi-purpose SFF connector replaces small mSATA and mini-PCIe slots. -
Single-sided design
Integrates easily into designs with M.2 connectors; ideal for thin and light systems.
- Kingston SSDNow - solid state drive - 480 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 480 GB
- Form Factor
- M.2 2280 (double-sided)
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- TRIM support, Wear Leveling Support, Advanced Garbage Collection, DevSleep mode
- 22 mm x 80 mm x 3.5 mm
- 7.98 g
- 5-year warranty
- Capacity
- 480 GB
- Form Factor
- Interface
- SATA 6Gb/s
- 22 mm
- 80 mm
- 3.5 mm
- 7.98 g
Performance
- Drive Writes Per Day (DWPD)
- 0.93
- SSD Endurance
- 800 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 550 MBps (read) / 520 MBps (write)
- 4KB Random Read
- 80000 IOPS
- 4KB Random Write
- 80000 IOPS
- Maximum 4KB Random Write
- 85000 IOPS
- Maximum 4KB Random Read
- 90000 IOPS
Reliability
- MTBF
- 1,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - M.2 Card
- Compatible Bay
- Power Consumption
- 0.06 Watt (idle) , 1.56 Watt (read) , 3.01 Watt (write)
- Limited warranty - 5 years
- 0 °C
- 70 °C
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
