Next-generation SSD technology
Kingston’s M.2 SATA G2 SSD is a thin and compact, caseless internal solid-state drive that combines high capacity with low power consumption to serve as a reliable caching device or primary storage for the O/S and applications. Suitable for desktop motherboards that use the Intel 9x chipset and popular small-form-factor (SFF) PCs including ultrabooks, notebooks and tablets, the M.2 2280 SATA G2 SSD easily integrates into designs with M.2 connectors and is ideal for system builders and DIY end users.
Lighter weight than a cased SSD, the M.2 SATA G2 SSD optimises performance with advanced garbage collection, wear-levelling and TRIM support to keep performance consistent over the life of the drive.(1) DevSleep, a recent addition to the SATA specification, is an efficient power management option that minimises power consumption and extends battery life. Firmware-based power loss protection maintains data integrity and ensures that data in the cache is constantly flushed and hardened to NAND to enable the drive to recover in the event of an unsafe shutdown.
The complimentary Kingston SSD Manager (KSM) monitors warranty status and SSD health via the Kingston website. The M.2 SATA G2 SSD is backed by a limited five-year warranty(2), free technical support and legendary Kingston® reliability.
- Space-saving caseless design fits ultra-thin computing applications
- Multi-purpose SFF connector replaces small mSATA and mini-PCIe slots
- Capacities of up to 480GB(3)
- M.2 Gen 2 SSDs are backed by a limited five-year warranty(2)
1. Based on "out-of-box performance" using a SATA Rev. 3.0 motherboard. Speed may vary due to host hardware, software and usage. IOMETER random 4k random read/write is based on 8GB partition.
2. Limited warranty based on five years or SSD "Life Remaining" which can be found using the Kingston SSD Manager (kingston.com/SSDManager). A new, unused product will show a wear indicator value of one hundred (100), whereas a product that has reached its endurance limit of program erase cycles will show a wear indicator value of one (1). See kingston.com/wa for details.
3. Some of the listed capacity on a Flash storage device is used for formatting and other functions and is thus not available for data storage. As such, the actual available capacity for data storage is less than what is listed on the products. For more information, go to Kingston’s Flash memory Guide at kingston.com/flashguide.
M.2 form factor
Multi-purpose SFF connector replaces small mSATA and mini-PCIe slots. -
Single-sided design
Integrates easily into designs with M.2 connectors; ideal for thin and light systems.
- Kingston SSDNow - solid state drive - 120 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 120 GB
- Form Factor
- M.2 2280
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- TRIM support, Wear Leveling Support, Advanced Garbage Collection, DevSleep mode
- 22 mm x 80 mm x 3.5 mm
- 5.99 g
- 5-year warranty
- Capacity
- 120 GB
- Form Factor
- M.2 2280
- Interface
- SATA 6Gb/s
- 22 mm
- 80 mm
- 3.5 mm
- 5.99 g
Performance
- Drive Writes Per Day (DWPD)
- 0.56
- SSD Endurance
- 150 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 550 MBps (read) / 200 MBps (write)
- 4KB Random Read
- 80000 IOPS
- 4KB Random Write
- 48000 IOPS
- Maximum 4KB Random Write
- 90000 IOPS
- Maximum 4KB Random Read
- 48000 IOPS
Reliability
- MTBF
- 1,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - M.2 Card
- Compatible Bay
- M.2 2280
- Power Consumption
- 0.06 Watt (idle) , 1.56 Watt (read) , 3.01 Watt (write)
- Limited warranty - 5 years
- 0 °C
- 70 °C
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
