Product
Brand
Kingston SSDNow 120GB M.2 SATA 6Gbps Single Side
Quicklinx: BX2KWS00 Mfr#: SM2280S3G2/120G
Form Factor: M.2 2280
Capacity: 120GB
Interface: Serial ATA-600
Type: Internal hard drive
Stock Status: Clearance
£40.56 ex VAT
£48.67 inc VAT
Express delivery Delivered on Tuesday
Next-generation SSD technology
Kingston’s M.2 SATA G2 SSD is a thin and compact, caseless internal solid-state drive that combines high capacity with low power consumption to serve as a reliable caching device or primary storage for the O/S and applications. Suitable for desktop motherboards that use the Intel 9x chipset and popular small-form-factor (SFF) PCs including ultrabooks, notebooks and tablets, the M.2 2280 SATA G2 SSD easily integrates into designs with M.2 connectors and is ideal for system builders and DIY end users.
Lighter weight than a cased SSD, the M.2 SATA G2 SSD optimises performance with advanced garbage collection, wear-levelling and TRIM support to keep performance consistent over the life of the drive.(1) DevSleep, a recent addition to the SATA specification, is an efficient power management option that minimises power consumption and extends battery life. Firmware-based power loss protection maintains data integrity and ensures that data in the cache is constantly flushed and hardened to NAND to enable the drive to recover in the event of an unsafe shutdown.
The complimentary Kingston SSD Manager (KSM) monitors warranty status and SSD health via the Kingston website. The M.2 SATA G2 SSD is backed by a limited five-year warranty(2), free technical support and legendary Kingston® reliability.
  • Space-saving caseless design fits ultra-thin computing applications
  • Multi-purpose SFF connector replaces small mSATA and mini-PCIe slots
  • Capacities of up to 480GB(3)
  • M.2 Gen 2 SSDs are backed by a limited five-year warranty(2)
1. Based on "out-of-box performance" using a SATA Rev. 3.0 motherboard. Speed may vary due to host hardware, software and usage. IOMETER random 4k random read/write is based on 8GB partition.
2. Limited warranty based on five years or SSD "Life Remaining" which can be found using the Kingston SSD Manager (kingston.com/SSDManager). A new, unused product will show a wear indicator value of one hundred (100), whereas a product that has reached its endurance limit of program erase cycles will show a wear indicator value of one (1). See kingston.com/wa for details.
3. Some of the listed capacity on a Flash storage device is used for formatting and other functions and is thus not available for data storage. As such, the actual available capacity for data storage is less than what is listed on the products. For more information, go to Kingston’s Flash memory Guide at kingston.com/flashguide.
Kingston SSDNow - solid state drive - 120 GB - SATA 6Gb/s
Solid state drive - internal
120 GB
M.2 2280
SATA 6Gb/s
Data Transfer Rate
600 MBps
TRIM support, Wear Leveling Support, Advanced Garbage Collection, DevSleep mode
22 mm x 80 mm x 3.5 mm
5.99 g
5 years warranty
120 GB
M.2 2280
SATA 6Gb/s
22 mm
80 mm
3.5 mm
5.99 g
Performance
Drive Writes Per Day (DWPD)
0.56
SSD Endurance
150 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 200 MBps (write)
4KB Random Read
80000 IOPS
4KB Random Write
48000 IOPS
Maximum 4KB Random Write
90000 IOPS
Maximum 4KB Random Read
48000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - M.2 Card
Compatible Bay
M.2 2280
Power Consumption
0.06 Watt (idle) , 1.56 Watt (read) , 3.01 Watt (write)
Limited warranty - 5 years
70 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
Capacity: 120GB
Brand: Kingston
Price Range Ex VAT: 0 - 50
