Product
Kingston MobileLite G4 USB 3.0 Multi-card Reader
Quicklinx: 9K07WS00 Mfr#: FCR-MLG4
Supported Formats: microSD, microSDHC, microSDHC UHS-I Memory Card, microSDXC + 8 more
Interface: USB 3.0
More than 50 in stock
£7.20 ex VAT
£8.64 inc VAT
Kingston's MobileLite G4 is a multi-function card reader with a small metallic form factor that's roughly 20 per cent smaller than the previous generation and no bigger than a large paper clip, so it easily fits into a pocket, wallet or camera bag and is ideal for personal or professional use. This versatile device reads SD, SDHC, SDXC, UHS-II and microSD/SDHC/SDXC, UHS-I and supports the latest card speeds.
MobileLite G4 is compliant with the USB 3.0 speciflfication and delivers USB 3.0 performance to save time when transferring digital flfiles, photos, games, music and more. It's backwards-compatible with USB 2.0 ports to allow users to migrate to USB 3.0 in the future, using one card reader. MobileLite G4 is backed by a two-year warranty, free technical support and legendary Kingston® reliability.
  • Portable, sleek metallic design
  • USB 3.0 multi-function card reader
  • Backwards-compatible with USB 2.0
Kingston MobileLite G4 - card reader - USB 3.0
Card reader - external
Supported Memory Cards
SD Memory Card, microSD, SDHC Memory Card, microSDHC, SDXC Memory Card, microSDXC, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card, microSDHC UHS-I Memory Card, microSDXC UHS-I Memory Card, SDHC UHS-II Memory Card, SDXC UHS-II Memory Card
Host Interface
USB 3.0
2 years warranty
Host Interface
USB 3.0
52 mm
33 mm
9 mm
Required Ports
1 x 9 pin USB Type A
Linux Kernel 2.6.x or later, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Apple MacOS X 10.6.x or later, Microsoft Windows 7 SP1, Windows 8, Microsoft Windows RT, Windows 8.1
Supported Formats: microSDHC
Supported Formats: microSDHC UHS-I Memory Card
Supported Formats: microSDXC
Supported Formats: microSDXC UHS-I Memory Card
Supported Formats: SD Memory Card
Supported Formats: SDHC Memory Card
Supported Formats: SDHC UHS-I Memory Card
Supported Formats: SDHC UHS-II Memory Card
Supported Formats: SDXC Memory Card
Supported Formats: SDXC UHS-I Memory Card
Supported Formats: SDXC UHS-II Memory Card
Interface: USB 3.0
Brand: Kingston
Price Range Ex VAT: 0 - 50
