Product
Brand
Kingston KVR 12GB 1600MHz DDR3L ECC Reg Memory Module
Quicklinx: 98BHWS00 Mfr#: KVR16LR11S8K3/12
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3L - 12 GB: 3 x 4 GB - DIMM 240-pin
RAM memory
12 GB: 3 x 4 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11 (11-11-11)
Temperature monitoring, single rank, eight banks, On-Die Termination (ODT), triple channel, Low Voltage, registered with parity
Voltage
1.35 / 1.5 V
Lead Plating
Gold
12 GB: 3 x 4 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
DIMM 240-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL11 (11-11-11)
ECC
Module Configuration
512 x 72
Chips Organization
512 x 8
Voltage
1.35 / 1.5 V
Lead Plating
Gold
Compatible Slots
3 x memory - DIMM 240-pin
