- Kingston - DDR3 - 8 GB - DIMM 240-pin
- Product Type
- RAM memory
- Capacity
- 8 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1600 MHz (PC3-12800)
- Latency Timings
- CL11
- Single rank, registered
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Limited lifetime warranty
- Designed For
- Sun Blade X6270, X6270 M2, X6270 M2 Server Module, X6270 M3, X6270 Server Module, X6275, X6275 M2 Server Module, X6275 Server Module; Fire X2270, X2270 ATO base chassis package, X2270 M2, X4170, X4170 M2, X4170 M2 Server, X4170 M3 Server, X4270, X4270 M2, X4270 M3, X4275
- Capacity
- 8 GB
- Upgrade Type
- System specific
- DRAM
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Latency Timings
- CL11
- ECC
- Module Configuration
- 1024 X 72
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- Sun Blade X6270, X6270 M2, X6270 M2 Server Module, X6270 M3, X6270 Server Module, X6275, X6275 M2 Server Module, X6275 Server Module , Sun Fire X2270, X2270 ATO base chassis package, X2270 M2, X4170, X4170 M2, X4170 M2 Server, X4170 M3 Server, X4270, X4270 M2, X4270 M3, X4275
