Your basket is empty
Kingston KTC 8GB 1600MHz Reg ECC DDR3 Memory
Quicklinx: 9QR3WS00 Mfr#: KTH-PL316LV/8G
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3L - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11
Low Voltage, registered
Voltage
1.35 V
Lead Plating
Gold
HP 713983-B21, HP 731765-B21
Limited lifetime warranty (Russia - 10 years)
8 GB
Upgrade Type
System specific
DRAM
DDR3L SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
1024 X 72
Voltage
1.35 V
Lead Plating
Gold
Compatible Slots
1 x memory
