Kingston Technology is the world's independent memory leader and is well-known for providing high quality memory products at an attractive price. Kingston ValueRAM is your best source for industry-standard memory to maximise the performance and productivity of your system. Built with A-grade components only, Kingston ValueRAM memory modules come with a lifetime warranty.
- Kingston - DDR3L - 8 GB - DIMM 240-pin
- Product Type
- RAM memory
- Capacity
- 8 GB
- Memory Type
- DDR3L SDRAM - DIMM 240-pin very low profile
- Upgrade Type
- Generic
- Data Integrity Check
- ECC
- Speed
- 1600 MHz (PC3-12800)
- Latency Timings
- CL11
- Unbuffered
- Voltage
- 1.35 V
- Limited lifetime warranty
- Capacity
- 8 GB
- Upgrade Type
- Generic
- DRAM
- Technology
- DDR3L SDRAM
- Form Factor
- Speed
- Latency Timings
- CL11
- ECC
- Unbuffered
- Module Configuration
- 1 x 72
- Voltage
- 1.35 V
- Compatible Slots
- Memory - DIMM 240-pin
