Your basket is empty
Kingston KTC 8GB 1333MHz ECC Memory Module
Quicklinx: 9585WS00 Mfr#: KTH-PL313E/8G
Type: DDR3 SDRAM
Capacity: 8GB
Connection: DIMM 240-pin
Speed: 1333MHz
Data Integrity: ECC
More than 50 in stock
£62.92 ex VAT
£75.50 inc VAT
Standard delivery Delivered within 3-5 working days
Marketing description is not available.
Kingston - DDR3 - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1333 MHz (PC3-10600)
Unbuffered
Limited lifetime warranty (Russia - 10 years)
HPE ProLiant BL420c Gen8, BL460c Gen8, DL160 Gen8, DL320e Gen8, DL360e Gen8, DL360p Gen8, DL380e Gen8, DL380p Gen8, MicroServer Gen8, ML310e Gen8, ML350e Gen8, ML350p Gen8, SL230s Gen8, SL250s Gen8, SL270s Gen8, WS460c Gen8, XL220a Gen8
8 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
DIMM 240-pin
Speed
ECC
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
HPE ProLiant BL420c Gen8, BL460c Gen8, DL160 Gen8, DL160 Gen8 Base, DL160 Gen8 Entry, DL160 Gen8 Performance, DL320e Gen8, DL320e Gen8 Base, DL320e Gen8 Entry, DL320e Gen8 Performance, DL320e Gen8 v2 Base, DL320e Gen8 v2 Performance, DL360e Gen8, DL360e Gen8 Base, DL360e Gen8 Entry, DL360e Gen8 Performance, DL360e Gen8 Special Server, DL360p Gen8, DL360p Gen8 Base, DL360p Gen8 CMS, DL360p Gen8 Entry, DL360p Gen8 High Performance, DL360p Gen8 Performance, DL360p Gen8 Special Server, DL380e Gen8, DL380e Gen8 Base, DL380e Gen8 Entry, DL380e Gen8 High Performance, DL380e Gen8 Storage, DL380p Gen8, DL380p Gen8 Base, DL380p Gen8 Entry, DL380p Gen8 High Performance, DL380p Gen8 Performance, DL380p Gen8 Special, MicroServer Gen8, MicroServer Gen8 Base, MicroServer Gen8 Base Starter Kit, MicroServer Gen8 Entry, ML310e Gen8, ML310e Gen8 Base, ML310e Gen8 Entry, ML310e Gen8 Performance, ML310e Gen8 v2, ML310e Gen8 v2 Base, ML310e Gen8 v2 Enty, ML310e Gen8 v2 Performance, ML350e Gen8, ML350e Gen8 Base, ML350e Gen8 Entry, ML350e Gen8 Performance, ML350p Gen8, ML350p Gen8 Base, ML350p Gen8 Entry, ML350p Gen8 Performance, ML350p Gen8 Special Server, SL230s Gen8 1U Left Half Width Tray, SL230s Gen8 1U Right Half Width Tray, SL230s Gen8 Base 1U Left Tray Server, SL230s Gen8 Base 1U Right Tray Server, SL250s Gen8 2U Left Half Width Tray, SL250s Gen8 2U PCIe Gen3 Left Tray, SL250s Gen8 2U PCIe Gen3 Right Tray, SL250s Gen8 2U Right Half Width Tray, SL250s Gen8 Base 2U Left Half Width Tray, SL250s Gen8 Base 2U Left Tray Server, SL250s Gen8 Base 2U Right Half Width Tray, SL250s Gen8 Base 2U Right Tray Server, SL270s Gen8 1U Left Half Width Tray, SL270s Gen8 1U Right Half Width Tray, SL270s Gen8 Base 4U Left Half Width Tray, SL270s Gen8 Base 4U Right Half Width Tray, SL270s Gen8 SE 4U Left Tray, SL270s Gen8 SE 4U Right Tray, WS460c Gen8, XL220a Gen8 v2
Kingston KTC 8GB 1333MHz ECC Memory Module Bundle deal on Kingston KTC 8GB 1333MHz ECC Memory Module
£84.11
saving £14.13
Type: DDR3 SDRAM
Capacity: 8GB
Speed: 1333MHz
Data Integrity: ECC
Registered/Buffered: Unbuffered
Standard: PC3-10600
Brand: Kingston
Price Range Ex VAT: 50 - 100
