All Kingston® memory modules must perform properly to ensure maximum performance. Therefore, Kingston has developed an industry leading quality process to ensure that Kingston memory delivers superior quality, performance, and 100% compatibility with the computing system the module is designed for. Kingston, the world's largest independent memory manufacturer, has over 2, 000 memory products. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
- Kingston - DDR2 - 2 GB - SO-DIMM 200-pin
- Product Type
- RAM memory
- Capacity
- 2 GB
- Memory Type
- DDR2 SDRAM - SO-DIMM 200-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 800 MHz (PC2-6400)
- Unbuffered
- OEM Manufacturer Equivalent Part Number
- Toshiba PA3669U-1M2G
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Designed For
- Toshiba NB250; NB305; NB500; Portégé A600, M750, M750 3G-129, M800, R600; Qosmio F50, G50; Satellite A300, A350, A500, C650, L350, L450, L500, L500/049, L505, L550, L555, P300, P500, U400, U500, U505; Satellite Pro A300, C650, L300, L450, L500, L550, P300, S300, U400, U500; Tecra A10, M10, R10, S10
- Capacity
- 2 GB
- Upgrade Type
- System specific
- DRAM
- Technology
- DDR2 SDRAM
- Form Factor
- SO-DIMM 200-pin
- Speed
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - SO-DIMM 200-pin
- Designed For
- Toshiba Portégé A600-138, A600-139, A600-163, A600-SP2801A, M750-W7224V, M800-111, M800-701, R600-12U, R600-SP2803C , Toshiba Qosmio F50-11J, F50-11N, F50-126, F50-127, F50-12M, G50-11R, G50-11S, G50-12I, G50-12L, G50-12X , Toshiba Satellite A300-1KT, A300-1L6, A300-1MZ, A300-1OF, A300-1OG, A300-1PK, A300-1RD, A300-1SM, A300-1SZ, A300-20D, A300-20E, A300-20H, A300-20J, A300-20Q, A300-213, A300-214, A300-21D, A300-234, A300-23H, A300-259, A300-262, A300-27W, A300-27X, A300-29H, A300D-14T, A300D-15E, A300D-17R, A300D-205, A300D-208, A300D-209, A300D-20M, A300D-219, A350-00T, A350-00U, A350-00V, A350-04T, A350-04U, A350-10B, A350-10U, A350-11B, A350-208, A350-20B, A350-211, A350-217, A350-21L, A350-22J, A350D-200, A350D-201, L350-15C, L350-168, L350-200, L350-20J, L350-21F, L350-21M, L350-21P, L350-228, L350-22C, L350-22R, L350-22U, L350-23Q, L350-25T, L500-14F, L500-157, L500-17L, L500D-13U, L500D-14R, L500D-16G, P300-1GO, P300D-20U, U400-13K, U400-17T, U400-17U, U400-18E, U400-20U, U400-20V, U400-218, U400-24K, U400-ST6301, U505-S2002 , Toshiba Satellite Pro A300-108, A300-12H, A300-1BQ, A300-1HL, A300-219, A300-21A, A300-21B, A300-26P, L300-114, L300-20H, L300-24L, L300-24M, L300-29P, L300D-SP5802, L300D-SP5808A, L300-SP5917A, L300-SP6993A, P300-00C, P300-00D, P300-1GJ, S300-120, U400-11O, U400-14A, U400-14C, U400-14F, U400-15, U400-15Z, U400-16A, U400-18S, U400-206, U400-21E, U400-C01, U400-SP2804, U400-ST3301, U400-ST5404 , Toshiba Tecra A10-113, A10-11J, A10-11K, A10-11L, A10-12N, A10-14E, A10-15C, A10-19L, A10-1DX, A10-1E3, A10-1GL, A10-1K2, A10-SP5920C, A10-ST9010, M10-00M, M10-10I, M10-14C, M10-14J, M10-14K, M10-150, M10-15M, M10-16B, M10-16J, M10-16K, M10-16L, M10-17L, M10-18J, M10-198, M10-19W, M10-1CJ, M10-1DH, M10-1E4, M10-1HP, M10-SP5922C, M10-SP5922R, M10-ST9110, M10-ST9117, R10-10P, R10-123, R10-12M, R10-146, R10-147, R10-149, R10-151, S10-00X, S10-125, S10-12G, S10-12P, S10-144, S10-MN6, S10-MN8
