Kingston is the world's largest independent memory manufacturer. In today's performance-driven environment, memory upgrades provide an easy, economical alternative to increase system performance. Every memory product Kingston offers is designed to help you get maximum performance at the best price to you.
- Kingston - DDR2 - 2 GB - DIMM 240-pin
- Product Type
- RAM memory
- Capacity
- 2 GB
- Memory Type
- DDR2 SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- Non-ECC
- Speed
- 667 MHz (PC2-5300)
- Unbuffered
- OEM Manufacturer Equivalent Part Number
- IBM 73P4985, IBM 41X4257, IBM 43R2002, IBM 30R5127
- Limited lifetime warranty (Germany, Austria and France - 10 years)
- Designed For
- IBM SurePOS 700; Lenovo H210; IdeaCentre K200; K210; J100; J115; J200p; J205; K100; Q100; S205; ThinkCentre A52; A55; A57; A58; A60; A61; A62; M52; M55; M55e; M55p; M57; M57e; M57p; M58e
- Capacity
- 2 GB
- Upgrade Type
- System specific
- DRAM
- Technology
- DDR2 SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- Non-ECC
- Unbuffered
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- IBM SurePOS 700 4800-743, 4800-783 , Lenovo H210 5355 , Lenovo IdeaCentre K200 , Lenovo IdeaCentre K210 5313 , Lenovo J100 8255, 8256, 8456, 8457 , Lenovo J115 7387, 7388, 7389, 7390, 7391, 7392 , Lenovo J200p 9689 , Lenovo J205 9686, 9687 , Lenovo K100 , Lenovo Q100 8822 , Lenovo S205 9680 , Lenovo ThinkCentre A52 8154, 8155, 8156, 8161, 8162, 8164, 8288, 8289, 8297, 8298, 8326, 8327, 8328, 8329, 8340, 8341, 8342, 8343, 8344, 8380, 8381, 8382, 8782, 8783, 8784, 8785, 8786, 8788 , Lenovo ThinkCentre A55 8705, 8706, 8972, 8975, 8982, 8985, 8994, 9265, 9636, 9640, 9641 , Lenovo ThinkCentre A57 9702, 9703, 9704, 9851, 9859 , Lenovo ThinkCentre A58 7522, 7611, 7705 , Lenovo ThinkCentre A60 8013, 8700, 8976, 8979, 8986, 8991, 9266, 9269, 9282, 9283, 9374, 9383, 9384, 9631 , Lenovo ThinkCentre A61 9120, 9126, 9129, 9134, 9135, 9136, 9137, 9141, 9142, 9143, 9144, 9156, 9157, 9158, 9159, 9169, 9171, 9189, 9191 , Lenovo ThinkCentre A62 7057, 7061, 7062, 9485, 9486, 9623, 9624, 9625, 9705, 9935, 9953 , Lenovo ThinkCentre M52 8112, 8116, 8211, 8214 , Lenovo ThinkCentre M55 6488, 8009, 8010, 8791, 8792, 8795, 8796, 8799, 8800, 8801, 8802, 8803, 8804, 8805, 8806, 8807, 8808, 8810, 8811, 8812, 8813, 8814, 8816 , Lenovo ThinkCentre M55e 9278, 9279, 9288, 9379, 9380, 9389, 9632, 9637, 9642, 9644, 9645 , Lenovo ThinkCentre M55p 8792, 8794, 8796, 8798, 8800, 8802, 8804, 8806, 8808, 8811, 8813, 8816 , Lenovo ThinkCentre M57 6008, 6010, 6019, 6062, 6065, 6066, 6067, 6068, 6069, 6071, 6072, 6073, 6074, 6075, 6076, 6077, 6079, 6081, 6082, 6086, 6087, 6089, 9172, 9174, 9181, 9970, 9978 , Lenovo ThinkCentre M57e 6179, 6305, 9356, 9438, 9439, 9481, 9482, 9487, 9488, 9622 , Lenovo ThinkCentre M57p 6064, 6067, 6073, 6078, 9011, 9012, 9013, 9014, 9018, 9019, 9071, 9087, 9088, 9089, 9096, 9160, 9162, 9163, 9164, 9193, 9194, 9196, 9967, 9979 , Lenovo ThinkCentre M58e 7259, 7268, 7269, 7270, 7279, 7298, 7303, 7307, 7408, 7491, 7506, 7508, 7514
