Kingston KTC 16GB 2133MHz Reg ECC Module
Quicklinx: CFT9WS00 Mfr#: D2G72M151
Kingston - DDR4 - 16 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - CL15 - 1.2 V - registered - ECC - for Fujitsu PRIMERGY RX2540 M1
Kingston - DDR4 - module - 16 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - registered
Memory module
16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Registered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
16 GB
Upgrade Type
System specific
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL15
ECC
Registered
Module Configuration
2048 x 72
Voltage
1.2 V
Lead Plating
Gold
