Move to faster performance with Kingston's SDXC UHS-I U3 Flash card. It meets the SD Association's specification release, UHS-I U3 (Ultra High-Speed Bus, Speed Class 3), which guarantees performance of at least 30MB/s and enough bandwidth to record and play back 4K2K video without interruption. Users can capture cinema-quality full HD (1080p), ultra HD (2160p), 3D and 4K2K videos on high-performance cameras such as digital single lens reflex (D-SLR) and digital single lens mirrorless (D-SLM) cameras, camcorders and video cameras. It's ideal for television recordings as well as live broadcasts, plus it lets you edit files faster and provides faster upload times, especially when using USB 3.0 card readers. Its higher sustained write speeds ensure video integrity by reducing stutter and allow photographers to shoot in continuous burst mode.
- Kingston - flash memory card - 128 GB - SDXC UHS-I
- Product Type
- Flash memory card
- Form Factor
- SDXC UHS-I Memory Card
- Storage Capacity
- 128 GB
- Speed Rating
- UHS Class 3 / Class10
- Supply Voltage
- 3.3 V
- Limited lifetime warranty
- Product Type
- Flash memory card
- Storage Capacity
- 128 GB
- Speed Class
- Read Rate
- Up to 90 MB/s
- Write Rate
- Up to 80 MB/s
- Form Factor
- Supply Voltage
- 3.3 V
- Write protection switch
- Limited warranty - lifetime
- 24 mm
- 32 mm
- 2.1 mm
- -25 °C
- 85 °C
