Your basket is empty
Kingston KTC 128GB microSDXC Class10 SP
Quicklinx: BT8GWS00 Mfr#: SDC10G2/128GBSP
UHS-I speeds in a small, durable card.
Kingston's microSD Class 10 UHS-I card features Class 10 UHS-I speeds of 45 MB/s read and 10 MB/s write, making it ideal for photographers who shoot everything from still images to kids and pets in motion. It's also ideal for cinema-quality HD (1080p) video and reduces buffer time between shots when compared to the Class 4 card.
The smallest SD card available, microSD Class 10 UHS-I is the standard expandable storage option for many tablets, smartphones and action cameras.
Designed to withstand harsh environments, this versatile card is tested to be waterproof, temperature proof, shock and vibration proof and X-ray proof.
Kingston - flash memory card - 128 GB - microSDXC UHS-I
Flash memory card
microSDXC UHS-I Memory Card
Storage Capacity
128 GB
Speed Rating
UHS Class 1 / Class10
Flash memory card
Storage Capacity
128 GB
Compatibility
Non-specific
SD Speed Class
Read Rate
Up to 45 MB/s
Write Rate
Up to 10 MB/s
Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
Limited warranty - lifetime
11 mm
15 mm
Thickness
1 mm
-25 °C
85 °C
