Your basket is empty
Kingston HyperX Savage DDR4 8GB DIMM 288-pin 2800 MHz/PC4-22400 CL14 1.35V unbuffered non-ECC
Quicklinx: BVVWWS00 Mfr#: HX428C14SB2/8
Type: DDR4 SDRAM
Capacity: 8GB
Connection: DIMM 288-pin
Speed: 2800MHz
Data Integrity: Non-ECC
More than 50 in stock
£53.78 ex VAT
£64.53 inc VAT
Standard delivery Delivered within 3-5 working days
Marketing description is not available.
HyperX Savage - DDR4 - 8 GB - DIMM 288-pin
RAM memory
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2800 MHz ( PC4-22400 )
Latency Timings
CL14 ( 14-16-16 )
Dual rank, black heatsink, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), Black PCB, low profile heat spreader, sixteen banks, asymmetrical heatspreader , unbuffered
Voltage
1.35 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.36
Speed
Latency Timings
CL14 ( 14-16-16 )
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.35 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP) - 2666 MHz - 1.35 V - CL14 - 14-15-15 , Intel Extreme Memory Profiles (XMP) - 2800 MHz - 1.35 V - CL14 - 14-16-16
Colour Category
Kingston HyperX Savage DDR4 8GB DIMM 288-pin 2800 MHz/PC4-22400 CL14 1.35V unbuffered non-ECC Bundle deal on Kingston HyperX Savage DDR4 8GB DIMM 288-pin 2800 MHz/PC4-22400 CL14 1.35V unbuffered non-ECC
£70.10
saving £7.64
Type: DDR4 SDRAM
Capacity: 8GB
Speed: 2800MHz
Registered/Buffered: Unbuffered
CAS Latency: CL14
Standard: PC4-22400
Brand: Kingston
Price Range Ex VAT: 50 - 100
