HyperX Savage Black 8GB (2x4GB) DDR4 2800 MHz CL14 DIMM Memory
Quicklinx: BVVYWS00 Mfr#: HX428C14SB2K2/8
HyperX HX428C14SB2K2/8 is a kit of two 512M x 64-bit (4GB) DDR4-2800 CL14 SDRAM (Synchronous DRAM) 1Rx8, memory modules, based on eight 512M x 8-bit FBGA components per module. Total kit capacity is 8GB. Each module supports Intel® XMP (Extreme Memory Profiles). Each module has been tested to run at DDR4-2800 at a low latency timing of 14-16-16 at 1.35V. The SPDs are programmed to JEDEC standard latency DDR4-2133 timing of 15-15-15 at 1.2V. Each 288-pin DIMM uses gold contact fingers.
HyperX Savage - DDR4 - kit - 8 GB: 2 x 4 GB - DIMM 288-pin - 2800 MHz / PC4-22400 - unbuffered
Memory kit
8 GB: 2 x 4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2800 MHz (PC4-22400)
Latency Timings
CL14 (14-16-16)
Single rank, black heatsink, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), Black PCB, low profile heatspreader, sixteen banks, asymmetrical heatspreader, unbuffered
Voltage
1.35 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
8 GB: 2 x 4 GB
Upgrade Type
Generic
DRAM memory kit
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.36
Speed
Latency Timings
CL14 (14-16-16)
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.35 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP) - 2666 MHz - 1.35 V - CL14 - 14-15-15 , Intel Extreme Memory Profiles (XMP) - 2800 MHz - 1.35 V - CL14 - 14-16-16
Colour Category
