Your basket is empty
Kingston HyperX Savage DDR4 4GB DIMM 288-pin 3000 MHz/PC4-24000 CL15 1.35V unbuffered non-ECC
Quicklinx: BVW3WS00 Mfr#: HX430C15SB2/4
Type: DDR4 SDRAM
Capacity: 4GB
Connection: DIMM 288-pin
Speed: 3000MHz
Data Integrity: Non-ECC
35 in stock
£29.13 ex VAT
£34.95 inc VAT
Standard delivery Delivered within 3-5 working days
Marketing description is not available.
HyperX Savage - DDR4 - 4 GB - DIMM 288-pin
RAM memory
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3000 MHz ( PC4-24000 )
Latency Timings
CL15 ( 15-17-17 )
Single rank, black heatsink, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), Black PCB, low profile heat spreader, sixteen banks, asymmetrical heatspreader , unbuffered
Voltage
1.35 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.36
Speed
Latency Timings
CL15 ( 15-17-17 )
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.35 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP) - 2666 MHz - 1.35 V - CL14 - 14-15-15 , Intel Extreme Memory Profiles (XMP) - 3000 MHz - 1.35 V - CL15 - 15-17-17
Colour Category
Kingston HyperX Savage DDR4 4GB DIMM 288-pin 3000 MHz/PC4-24000 CL15 1.35V unbuffered non-ECC Bundle deal on Kingston HyperX Savage DDR4 4GB DIMM 288-pin 3000 MHz/PC4-24000 CL15 1.35V unbuffered non-ECC
£45.45
saving £8.20
Type: DDR4 SDRAM
Capacity: 4GB
Speed: 3000MHz
Registered/Buffered: Unbuffered
CAS Latency: CL15
Standard: PC4-24000
Brand: Kingston
Price Range Ex VAT: 0 - 50
