HyperX Savage Black 32GB (4x8GB) DDR4 3000 MHz CL15 DIMM Memory
Quicklinx: BVW9WS00 Mfr#: HX430C15SB2K4/32
HyperX HX430C15SB2K4/32 is a kit of four 1G x 64-bit (8GB) DDR4-3000 CL15 SDRAM (Synchronous DRAM) 2Rx8, memory modules, based on sixteen 512M x 8-bit FBGA components per module. Total kit capacity is 32GB. Each module supports IntelĀ® XMP (Extreme Memory Profiles). Each module has been tested to run at DDR4-3000 at a low latency timing of 15-17-17 at 1.35V. The SPDs are programmed to JEDEC standard latency DDR4-2133 timing of 15-15-15 at 1.2V. Each 288-pin DIMM uses gold contact fingers.
HyperX Savage - DDR4 - kit - 32 GB: 4 x 8 GB - DIMM 288-pin - 3000 MHz / PC4-24000 - unbuffered
Memory kit
32 GB: 4 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
3000 MHz (PC4-24000)
Latency Timings
CL15 (15-17-17)
Dual rank, black heatsink, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), Black PCB, low profile heatspreader, sixteen banks, asymmetrical heatspreader, unbuffered
Voltage
1.35 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM memory kit
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.36
Speed
Latency Timings
CL15 (15-17-17)
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.35 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP) - 2666 MHz - 1.35 V - CL14 - 14-15-15 , Intel Extreme Memory Profiles (XMP) - 3000 MHz - 1.35 V - CL15 - 15-17-17
Colour Category
