Your basket is empty
Kingston HyperX Savage DDR4 16GB (2x8GB) DIMM 288-pin 2400 MHz/PC4-19200 CL12 1.35V unbuffered
Quicklinx: BVVJWS00 Mfr#: HX424C12SB2K2/16
Type: DDR4 SDRAM
Capacity: 16GB
Connection: DIMM 288-pin
Speed: 2400MHz
Data Integrity: Non-ECC
More than 50 in stock
£114.31 ex VAT
£137.17 inc VAT
Marketing description is not available.
HyperX Savage - DDR4 - 16 GB: 2 x 8 GB - DIMM 288-pin
RAM memory
16 GB: 2 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL12 (12-14-14)
Dual rank, black heatsink, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), Black PCB, low profile heat spreader, sixteen banks, asymmetrical heatspreader, unbuffered
Voltage
1.35 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.36
Speed
Latency Timings
CL12 (12-14-14)
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.35 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP) - 2133 MHz - 1.2 V - CL13 - 13-13-13 , Intel Extreme Memory Profiles (XMP) - 2400 MHz - 1.35 V - CL12 - 12-14-14
Colour Category
Kingston HyperX Savage DDR4 16GB (2x8GB) DIMM 288-pin 2400 MHz/PC4-19200 CL12 1.35V unbuffered Bundle deal on Kingston HyperX Savage DDR4 16GB (2x8GB) DIMM 288-pin 2400 MHz/PC4-19200 CL12 1.35V unbuffered
£130.63
saving £8.65
Type: DDR4 SDRAM
Capacity: 16GB
Speed: 2400MHz
Registered/Buffered: Unbuffered
CAS Latency: CL12
Standard: PC4-19200
Brand: Kingston
Price Range Ex VAT: 100 - 150
