HyperX FURY Black 32GB (4x8GB) DDR4 2133 MHz CL14 DIMM Memory
Quicklinx: B3T4WS00 Mfr#: HX421C14FBK4/32
Engineered and tested to deliver extreme performance, Kingston HyperX easily endures the most rigorous demands of any creative professional, gamer or PC enthusiast.
HyperX® FURY DDR4
Automatic overclocking for X99 platforms
HyperX® FURY DDR4 can handle even the toughest battle. It automatically recognises its host platform and overclocks to the highest frequency published (up to 2666MHz1) -- so you can wreak havoc. FURY DDR4 runs at 1.2V, even at 2666MHz, so it stays cooler while you play. You don't need to alter the voltage to reach higher speeds, which means there's more power for other hardware in the system. FURY's sleek, asymmetrical black heat spreader provides enhanced thermal dissipation to help keep your cool and help you stand out from the crowd.
Automatic overclocking -- up to 2666MHz
CAS latency CL14-CL15
Low power consumption -- 1.2V
Optimised for Intel's X99 chipset
DDR4 is not compatible with older Intel or AMD chipsets
Benefits
Easy to install -- plug-and-play functionality
Automatic overclocking -- reach faster speeds and higher capacities just by installing the memory, no adjustments in BIOS needed
Cost-efficient -- the perfect combination of price and DDR4 performance
Unique -- asymmetrical, signature FURY heat spreader
Design -- low-profile, black heat spreader colour and matching PCB
Reliable -- 100% factory tested
Compatible -- tested with all popular brands of motherboards
Guaranteed -- lifetime warranty, free technical support
HyperX FURY - DDR4 - kit - 32 GB: 4 x 8 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - unbuffered
Memory kit
32 GB: 4 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL14 (14-14-14)
Single rank, black heatsink, On-Die Termination (ODT), dual channel, Black PCB, quad channel, low profile heatspreader, FURY asymmetric heatspreader, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM memory kit
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.34
Speed
Latency Timings
CL14 (14-14-14)
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.2 V
Lead Plating
Gold
Colour Category
