HyperX FURY Black 32GB (4x8GB) DDR4 2666MHz CL15 DIMM Memory
Quicklinx: B3TDWS00 Mfr#: HX426C15FBK4/32
Plug and Play for high performance with Intel's 100 Series and X99 chipsets.
HyperX FURY DDR4 memory automatically overclocks to the highest frequency published, up to 2666 MHz, to deliver instant top-level performance for motherboards with Intel's 100 Series and X99 chipsets.
It's a small investment for premium components that complement Intel's 2, 4, 6 and 8-core processors for faster video editing, 3D rendering, gaming and AI processing.
Its stylish low-profile heat spreader with signature FURY design lets you show off your rig in style.
HyperX FURY - DDR4 - kit - 32 GB: 4 x 8 GB - DIMM 288-pin - 2666 MHz / PC4-21300 - unbuffered
Memory kit
32 GB: 4 x 8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2666 MHz (PC4-21300)
Latency Timings
CL15 (15-17-17)
Single rank, black heatsink, On-Die Termination (ODT), dual channel, Black PCB, quad channel, low profile heatspreader, FURY asymmetric heatspreader, sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
32 GB: 4 x 8 GB
Upgrade Type
Generic
DRAM memory kit
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.34
Speed
Latency Timings
CL15 (15-17-17)
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.2 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL12 - 12-14-14 , SPD - 2400 MHz - 1.2 V - CL14 - 14-16-16 , SPD - 2666 MHz - 1.2 V - CL15 - 15-17-17 , Intel Extreme Memory Profiles (XMP 2.0) - 2666 MHz - 1.2 V - CL15 - 15-17-17
Colour Category
