HyperX HX424S15IBK4/32 is a kit of four 1G x 64-bit (8GB) DDR4-2400 CL15 SDRAM (Synchronous DRAM) 2Rx8, memory modules, based on sixteen 512M x 8-bit DDR4 FBGA components. Total kit capacity is 32GB. Each module supports Intel® Extreme Memory Profiles (Intel® XMP) 2.0. This module has been tested to run at DDR4-2400 at a low latency timing of 15-15-15 at 1.2V.
- HyperX Impact - DDR4 - kit - 32 GB: 4 x 8 GB - SO-DIMM 260-pin - 2400 MHz / PC4-19200 - unbuffered
- Product Type
- Memory kit
- Capacity
- 32 GB: 4 x 8 GB
- Memory Type
- DDR4 SDRAM - SO-DIMM 260-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 2400 MHz (PC4-19200)
- Latency Timings
- CL15 (15-15-15)
- Dual rank, On-Die Termination (ODT), sixteen banks, Intel Extreme Memory Profiles (XMP 2.0), unbuffered
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 32 GB: 4 x 8 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR4 SDRAM
- Form Factor
- SO-DIMM 260-pin
- Module Height (inch)
- 1.18
- Speed
- Latency Timings
- CL15 (15-15-15)
- Non-ECC
- Module Configuration
- 1024 x 64
- Chips Organization
- 512 x 8
- Voltage
- 1.2 V
- Lead Plating
- Gold
- RAM Performance
- SPD - 2133 MHz - 1.2 V - CL14 - 14-14-14 , Intel Extreme Memory Profiles (XMP 2.0) - 2400 MHz - 1.2 V - CL15 - 15-15-15
- Colour Category
- Black
