Your basket is empty
Kingston HyperX 16GB 2133MHz DDR4 CL14 SODIMM Kit
Quicklinx: BYF0WS00 Mfr#: HX421S14IBK4/16
Type: DDR4 SDRAM
Capacity: 16GB
Connection: SO-DIMM 260-pin
Speed: 2133MHz
Data Integrity: Non-ECC
£95.00 ex VAT
£114.00 inc VAT
HyperX HX421S14IBK4/16 is a kit of four 512M x 64-bit (4GB) DDR4-2133 CL14 SDRAM (Synchronous DRAM) 1Rx8, memory modules, based on eight 512M x 8-bit DDR4 FBGA components. Total kit capacity is 16GB. Each module kit supports Intel® Extreme Memory Profiles (Intel® XMP) 2.0. This module has been tested to run at DDR4-2133 at a low latency timing of 14-14-14 at 1.2V.
Kingston HyperX Impact - DDR4 - 16 GB : 4 x 4 GB - SO-DIMM 260-pin
RAM memory
16 GB : 4 x 4 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz ( PC4-17000 )
Latency Timings
CL14 ( 14-14-14 )
Single rank, On-Die Termination (ODT), sixteen banks, Intel Extreme Memory Profiles (XMP 2.0) , unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
16 GB : 4 x 4 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
SO-DIMM 260-pin
Module Height (inch)
1.18
Speed
Latency Timings
CL14 ( 14-14-14 )
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.2 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL14 - 14-14-14 , Intel Extreme Memory Profiles (XMP 2.0) - 2133 MHz - 1.2 V - CL14 - 14-14-14
Colour Category
Kingston HyperX 16GB 2133MHz DDR4 CL14 SODIMM Kit Bundle deal on Kingston HyperX 16GB 2133MHz DDR4 CL14 SODIMM Kit
£111.32
saving £7.64
Type: DDR4 SDRAM
Capacity: 16GB
Speed: 2133MHz
Registered/Buffered: Unbuffered
CAS Latency: CL14
Standard: PC4-17000
Brand: Kingston
Price Range Ex VAT: 50 - 100
