Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
- Kingston - DDR4 - 8 GB - DIMM 288-pin
- Product Type
- RAM memory
- Capacity
- 8 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15
- Registered
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Limited lifetime warranty (Russia - 10 years)
- Designed For
- Dell PowerEdge FC430, FC630, FC830, M630, M830, R430, R530, R630, R730, R930, T430, T630; Precision Tower 5810, 7810, 7910
- Capacity
- 8 GB
- Upgrade Type
- System specific
- DRAM
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL15
- ECC
- Registered
- Module Configuration
- 1024 X 72
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Designed For
- Dell PowerEdge FC430, FC630, FC830, M630, M830, R430, R530, R630, R730, R930, T430, T630 , Dell Precision Tower 5810, 7810, 7910
