Product
Brand
Kingston DDR4 16GB SO-DIMM 260-pin 2133 MHz/PC4-17000 CL15 1.2 V unbuffered non-ECC
Quicklinx: BWN0WS00 Mfr#: KCP421SD8/16
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR4 - 16 GB - SO-DIMM 260-pin
RAM memory
16 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2133 MHz (PC4-17000)
Latency Timings
CL15
Unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
16 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Latency Timings
CL15
Non-ECC
Unbuffered
Module Configuration
2048 x 64
Voltage
1.2 V
Lead Plating
Gold
