Product
Brand
Kingston DDR3L 8GB DIMM 240-pin 1600 MHz/PC3-12800 CL11 1.35 V unbuffered ECC
Quicklinx: BW0WWS00 Mfr#: D1G72KL110
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3L - 8 GB - DIMM 240-pin
RAM memory
8 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Low Voltage, unbuffered
Voltage
1.35 V
NEC Express5800 E120d-M
8 GB
Upgrade Type
System specific
DRAM
DDR3L SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
1024 X 72
Voltage
1.35 V
Compatible Slots
1 x memory - DIMM 240-pin
