Product
Brand
Kingston DDR3 32GB LRDIMM 240-pin 1866 MHz/PC3-14900 CL13 1.5 V Load-Reduced ECC
Quicklinx: BW0TWS00 Mfr#: KTD-PE318LQ/32G
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3 - 32 GB - LRDIMM 240-pin
RAM memory
32 GB
Memory Type
DDR3 SDRAM - LRDIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1866 MHz (PC3-14900)
Latency Timings
CL13
Quad rank, Load-Reduced
Voltage
1.5 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
Dell PowerEdge M620, R620, R720, R720xd, T620
32 GB
Upgrade Type
System specific
DRAM
DDR3 SDRAM
LRDIMM 240-pin
Speed
Latency Timings
CL13
ECC
Module Configuration
4096 x 72
Voltage
1.5 V
Lead Plating
Gold
