Product
Kingston DDR3 16GB 1600MHz/PC3-12800 Registered ECC Low Voltage Module
Quicklinx: BW0VWS00 Mfr#: KTH-PL316LV/16G
Type: DDR3L SDRAM
Capacity: 16GB
Connection: DIMM 240-pin
Speed: 1600MHz
Data Integrity: ECC
£153.88 ex VAT
£184.65 inc VAT
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR3L - 16 GB - DIMM 240-pin - registered
RAM memory
16 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11
Dual rank, Low Voltage, registered
Voltage
1.35 V
Lead Plating
Gold
HP 664692-001, HP 713985-B21, HP 713985-S21, HP 715284-001, HP 713756-081
Limited lifetime warranty (Russia - 10 years)
16 GB
Upgrade Type
System specific
DRAM
DDR3L SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
2048 x 72
Voltage
1.35 V
Lead Plating
Gold
Compatible Slots
1 x memory
Type: DDR3L SDRAM
Capacity: 16GB
Speed: 1600MHz
Data Integrity: ECC
Registered/Buffered: Registered
CAS Latency: CL11
Standard: PC3L-12800
Brand: Kingston
Price Range Ex VAT: 150 - 300
