Product
Brand
Kingston DDR2 1GB DIMM 240-pin 800 MHz CL6 unbuffered
Quicklinx: BW11WS00 Mfr#: KTL2975C6/1G
Kingston Technology is the world’s independent memory leader and is well-known for providing high quality memory products at an attractive price. System Specific memory modules are designed and tested in the relevant systems prior to release; and they are guaranteed to be 100% compatible with your system. All Kingston System Specific memory come with a lifetime warranty.
Kingston - DDR2 - 1 GB - DIMM 240-pin
RAM memory
1 GB
Memory Type
DDR2 SDRAM - DIMM 240-pin
Upgrade Type
System specific
Speed
800 MHz
Latency Timings
CL6
Unbuffered
IBM 41U2977, IBM 41X1080
Limited lifetime warranty (Germany, Austria and France - 10 years)
Lenovo ThinkCentre A57; A61; M55; M55p; M57; M57e; M57p
1 GB
Upgrade Type
System specific
DRAM
DDR2 SDRAM
DIMM 240-pin
Speed
800 MHz
Latency Timings
CL6
Unbuffered
Compatible Slots
1 x memory - DIMM 240-pin
Lenovo ThinkCentre A57 , Lenovo ThinkCentre A61 , Lenovo ThinkCentre M55 , Lenovo ThinkCentre M55p , Lenovo ThinkCentre M57 , Lenovo ThinkCentre M57e , Lenovo ThinkCentre M57p
