Your basket is empty
Kingston DataTraveler Micro - USB flash drive - 8 GB - Black
Quicklinx: 8FRDWS00 Mfr#: DTMCK/8GB
Kingston's DataTraveler Micro is one of the world's smallest USB Flash drives. Mobile devices by nature need to be small and lightweight, which means that many of them come with limited storage. DataTraveler Micro is designed in an ultra-small form factor that can be left in the device while you're on the move.
USB flash drive
Interface Type
USB 2.0
Storage Capacity
8 GB
Enclosure Colour
Linux 2.6.x or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5.x or later
5 years warranty
USB flash drive
Storage Capacity
8 GB
Enclosure Colour
Compatibility
Non-specific
Interface Type
USB 2.0
Limited warranty - 5 years
25.6 mm
16.7 mm
8.4 mm
60 °C
