Kingston DataTraveler I G4 - USB 3.0 - 32GB
Quicklinx: 92FGWS00 Mfr#: DTIG4/32GB
DataTraveler G4 - USB 3.0 in a colourful design
USB 3.0 performance, backwards compatible with USB 2.0
Colorful loop attaches to key rings
Practical cap to protect USB plug and your data
Kingston's DataTraveler® Generation 4 (DTIG4) USB Flash drive features USB 3.0 for quick and easy transfers of music, video and more. Its practical design and fashionable colours make it ideal for everyday use at work, home, school or wherever you need to take your data.
It's backwards compatible with existing USB 2.0 ports, allowing 2.0 users to migrate to 3.0 in the future without replacing their drive. DTIG4 is backed by a five-year warranty, free technical support and legendary Kingston® reliability.
Capacity:
32GB
Dimensions:
55mm x 21mm x 10.1mm
Warranty/support:
5-year warranty, free technical support
Compatible with:
Windows® 8.1, Windows 8, Windows 7, Windows Vista®, Windows XP, Mac OS X v.10.6+, Linux v.2.6+ (USB 3.0 connectivity requires a USB 3.0 port)
Kingston DataTraveler G4 - USB flash drive - 32 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
32 GB
Enclosure Colour
Red
Microsoft Windows Vista, Linux 2.6 or later, Microsoft Windows 7 SP1, Google Chrome OS, Windows 8, Windows 8.1, Windows 10, Apple MacOS X 10.9.x or later
5-year warranty
USB flash drive
Storage Capacity
32 GB
Enclosure Colour
Red
Interface Type
USB 3.0
Key ring loop
Limited warranty - 5 years
67.3 mm
10.1 mm
21 mm
60 °C
