Kingston DataTraveler 64GB USB 3.0 Flash Drive
Quicklinx: 9FHPWS00 Mfr#: DTR30G2/64GB
Kingston's DataTraveler R3.0 G2 USB flash drive delivers USB 3.0 high-speed performance with speeds of 120 MB/s read and 45 MB/s write to save time when transferring files. It's 8 times faster than a standard 2.0 drive and saves an estimated 20 minutes when transferring a 1080p Full HD video. Its impressive speeds alleviate transfer bottleneck when storing or viewing HD video, music libraries, digital artwork, presentations and other large files.
With its rugged, rubberized casing, DTR30G2 is certified shock- and water-resistant so it can withstand knocks and bumps without damage while on the go.
  • Rugged design
    Designed to withstand the elements, the Kingston DataTraveler R3.0 G2 features a rubberized exterior that is not only shockproof but also water-resistant, ensuring your data stays safe in harsh conditions.
  • High-speed transfers
    With a USB 3.0 interface, this flash drive offers read rates of up to 120 MB/s, allowing for quick and efficient data transfers, making it an ideal solution for busy professionals and multimedia enthusiasts alike.
Kingston DataTraveler R3.0 G2 - USB flash drive - 64 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
64 GB
Linux 2.6.x or later, Microsoft Windows Vista SP2, Microsoft Windows Vista SP1, Apple MacOS X 10.6.x or later, Microsoft Windows 7 SP1, Windows 8, Windows 8.1, Windows RT
5-year warranty
USB flash drive
Storage Capacity
64 GB
Read Rate
Up to 120 MB/s
Write Rate
Up to 45 MB/s
Interface Type
USB 3.0
Shockproof, water resistant, rubberised
Limited warranty - 5 years
56 mm
22 mm
9.2 mm
60 °C
