Kingston's DataTraveler 4000 G2 offers high-end security and a tamper-evident seal for physical security to detect and respond to attempts at access, use or modification of the cryptographic module. It safeguards 100 percent of even sensitive data with 256-bit AES hardware-based encryption in XTS mode. For added peace of mind, the drive locks down and reformats after ten failed intrusion attempts and functions in read-only access mode to avoid malware risks. The drive is available with SafeConsole management, which allows IT professionals to centrally manage it to meet compliance requirements and provide a higher level of internal support. Activation is easy and can be done manually or with mass deployment tools. DT4000 G2's NAND and controller design allows for NAND to be interchanged without requalification and certification, so customers can add it to their standards list with confidence. DT4000 G2 offers impressive SuperSpeed USB 3.0 technology so users don't have to compromise speed for security. It's customizable and available with serial numbering, custom Product Identifier (PID) and other options to meet most frequently requested corporate IT requirements.
High-end FIPS validated security
100-percent of stored data is protected by hardware-based, 256-bit Advanced Encryption Standard (AES) in XTS mode. -
Tamper-evident seal
It is a physical security to detect and respond to attempts at physical access, use or modification of the cryptographic module. -
USB 3.0
This USB standard guarantees backwards compatibility with USB 2.0. -
Read-only access mode
When selected, access files in Read-only mode to avoid potential Malware risks. -
Enforced password protection
Complex password is user set with minimum characteristics to prevent unauthorized access. -
Secure
Drive locks down and reformats after 10 intrusion attempts. -
Easy to use
No admin rights or application installation required. -
Customizable
Preload content, password length, maximum number of password attempts and internal/external serialization numbering. -
Waterproof
It is protected against water damage.
- Kingston DataTraveler 4000 G2 - USB flash drive - 8 GB - TAA Compliant
- Product Type
- USB flash drive
- Interface Type
- USB 3.0
- Storage Capacity
- 8 GB
- Hardware Encryption
- Encryption Algorithm
- FIPS 140-2 Level 3, 256-bit AES
- Image Colour Disclaimer
- The displayed product image may be a different colour
- Technology
- NAND Flash
- OS Required
- Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows 7 SP1, Windows 8, Windows 8.1, Apple MacOS X 10.6.x - 10.9.x, Microsoft Windows RT 8.1, Microsoft Windows RT 8
- TAA Compliant
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 8 GB
- Read Rate
- Up to 165 MB/s
- Write Rate
- Up to 22 MB/s
- Interface Type
- USB 3.0
- Technology
- NAND Flash
- Password protection, waterproof, lockdown mode, tamper-proof, Access Control Function, ruggedized, stainless steel body, Read-Only Access Mode
- IEC 60529 IPX8
- TAA Compliant
- OS Required
- Limited warranty - 5 years
- 22.2 mm
- 12.05 mm
- 77.9 mm
- 0 °C
- 60 °C
