Product
Brand
Kingston DataTraveler 4000 G2 USB Flash Drive 4GB FIPS 140-2 Level 3
Quicklinx: BRH4WS00 Mfr#: DT4000G2/4GB
Kingston's DataTraveler 4000 G2 offers high-end security and a tamper-evident seal for physical security to detect and respond to attempts at access, use or modification of the cryptographic module. It safeguards 100 percent of even sensitive data with 256-bit AES hardware-based encryption in XTS mode. For added peace of mind, the drive locks down and reformats after ten failed intrusion attempts and functions in read-only access mode to avoid malware risks. The drive is available with SafeConsole management, which allows IT professionals to centrally manage it to meet compliance requirements and provide a higher level of internal support. Activation is easy and can be done manually or with mass deployment tools. DT4000 G2's NAND and controller design allows for NAND to be interchanged without requalification and certification, so customers can add it to their standards list with confidence. DT4000 G2 offers impressive SuperSpeed USB 3.0 technology so users don't have to compromise speed for security. It's customizable and available with serial numbering, custom Product Identifier (PID) and other options to meet most frequently requested corporate IT requirements.
Kingston DataTraveler 4000 G2 - USB flash drive - 4 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
4 GB
Hardware Encryption
Encryption Algorithm
FIPS 140-2 Level 3, 256-bit AES-XTS
NAND Flash
Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows 7 SP1, Windows 8, Windows 8.1, Microsoft Windows RT 8.1, Microsoft Windows RT 8, Apple MacOS X 10.7.x - 10.10.x
5 years warranty
USB flash drive
Storage Capacity
4 GB
Hardware Encryption
Compatibility
Non-specific
Read Rate
Up to 80 MB/s
Write Rate
Up to 12 MB/s
Interface Type
USB 3.0
NAND Flash
Password protection, waterproof, lockdown mode, tamper-proof, Access Control Function, ruggedized, stainless steel body, Read-Only Access Mode, titanium-coated, reformats after 10 failed login attempts
IEC 60529 IPX8
TAA Compliant
Limited warranty - 5 years
22.2 mm
12.1 mm
77.9 mm
60 °C
