Product
Kingston Datatraveler 16GB microDuo USB 3.0
Reduced Price - Whilst Stocks Last!
Quicklinx: 9LT2WS00 Mfr#: DTDUO3/16GB
Capacity: 16GB
Interface: USB 3.0
Stock Status: Clearance
Hurry, only 1 left in stock!
£5.70 ex VAT
£6.84 inc VAT
Express delivery Order within the next 9 hours for delivery tomorrow
Kingston's DataTraveler microDuo provides additional storage in a small, convenient form factor for tablets and smartphones that support the USB OTG (on-the-go) functionality. The USB OTG standard allows mobile devices to directly connect to supported USB devices.
DataTraveler microDuo allows microUSB ports, often used for charging devices, to be used as expansion ports for the additional memory. Ideal for storing large files while traveling, DTDUO gives Plug-and-Play functionality to tablets and smartphones without microSD ports at a lower price per GB than the extra built-in storage on a mobile device. With smartphones and tablets recording HD video and taking higher resolution photos, space on the device gets used up faster than ever. DTDUO lets users move files, photos, videos and more - without plugging into a PC - to offload or backup content. Sharing large files between mobile devices is easier than using online cloud services, and there's no need for a cable to transfer data between the device and a PC.
DT microDuo is small, lightweight and easy to take anywhere, plus its sleek design complements any mobile device. Its rotating cap protects the microUSB connector from damage.
  • USB OTG (On-The-Go)
    A standard which enables host functionality in certain phones/tablets with microUSB ports, enabling connectivity to USB devices like Kingston's DT microDuo.
  • 2-in-1
    MicroUSB and USB connectors for easy transfer of files between smartphones, tablets and computers.
  • Plug-and-Play
    Simply connect as you would a standard USB Flash drive.
  • Convenient
    Ultra-small, pocket-sized design for easy transportability.
Kingston DataTraveler microDuo - USB flash drive - 16 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
16 GB
Microsoft Windows 7, Microsoft Windows Vista, Linux 2.6 or later, Apple MacOS X 10.6.x or later, Windows 8, Microsoft Windows RT, Android 4.0 or later, Windows 8.1
5 years warranty
USB flash drive
Storage Capacity
16 GB
Compatibility
Non-specific
Read Rate
Up to 70 MB/s
Write Rate
Up to 10 MB/s
Interface Type
USB 3.0
USB On-The-Go compatible, swivel cap, micro-USB connector
Plug and Play
Limited warranty - 5 years
27.63 mm
16.46 mm
8.56 mm
60 °C
Capacity: 16GB
Interface: USB 3.0
Brand: Kingston
Price Range Ex VAT: 0 - 50
