Kingston 960GB UV500 M.2 2280 6GB/s SSD
Quicklinx: F8KSWS00 Mfr#: SUV500M8/960G
Form Factor: M.2 2280 (double-sided)
Capacity: 960GB
Interface: Serial ATA-600
Type: Internal hard drive
Hurry, only 1 left in stock!
£92.88 ex VAT
£111.45 inc VAT
Kingston's UV500 family of solid-state drives dramatically improves the responsiveness of your existing system with incredible boot, loading and transfer times. Powered by a Marvell Dean controller combined with 3D NAND Flash for read and write speeds up to 520 MB/s and 500 MB/s, this SSD is faster for better performance, ultra-responsive multitasking and an overall faster system. UV500 provides end-to-end data protection, supports 256-bit AES hardware-based encryption and TCG Opal 2.0 security management solutions. More reliable and durable, UV500 is built with NAND Flash semiconductor memory. There are no moving parts, making it far less likely to fail. It is also cooler and quieter, and its shock and vibration resistance makes it ideal for notebooks and other mobile computing devices.
  • Ideal for desktops and notebooks
    Offers an optimal form factor to fit in a wider array of systems. It is ideal for slimmer notebooks and systems with limited space.
  • Encrypted protection
    Protect sensitive data with support for 256-bit AES hardware-based encryption and TCG Opal 2.0.
  • Amazingly fast
    With incredible read/write speeds, the UV500 will not only increase performance, but can also breathe new life.
Kingston UV500 - solid state drive - 960 GB - SATA 6Gb/s
Solid state drive - internal - End-to-end data protection, 3D NAND Technology, Marvell 88SS1074 controller
960 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D triple-level cell (TLC)
SATA 6Gb/s
Data Transfer Rate
600 MBps
22 mm x 80 mm x 3.5 mm
5-year warranty
960 GB
Hardware Encryption
256-bit AES
SATA 6Gb/s
22 mm
80 mm
3.5 mm
Performance
SSD Endurance
480 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
520 MBps (read) / 500 MBps (write)
Maximum 4KB Random Write
45000 IOPS
Maximum 4KB Random Read
79000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - M.2 Card
Compatible Bay
Power Consumption
0.5 Watt (average) , 0.195 Watt (idle) , 1.17 Watt (read) , 2.32 Watt (write)
Limited warranty - 5 years , Technical support
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
Capacity: 960GB
Brand: Kingston
Price Range Ex VAT: 50 - 100
